Question about Vodavi Starplus SP7314-08 Corded Phone
Change display name.
I can change the time and date, but have no clue how to change the name(2nd line) on the display.
  • jeaniesue Apr 28, 2009
    Cannot figure out how to change the display name (2nd line).
    Could not understand just_bobz' solution.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If this hasn't been solved, I am Vodavi certified. Give me a ring
Posted on Jan 07, 2009
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Nov 03, 2017 | Avaya Lands Phones
How to change display
Actually it probably is. What happens when you press "*" on an idle phone?
Feb 25, 2013 | Panasonic KX-T7736 Corded Phone (KXT7736)
How to set the time and date
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Oct 25, 2010 | Nortel T7316E 2-Line Corded Phone
HOW TO CHANGE NAME ON MY T7316E
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
7.- Select AM or PM
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
16.- Enter month
19.- Enter day
Mar 15, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Display name / date time
1)First tell me mob-ph-whitch company.2)mob-ph-Model-no-otherwise donot solve.
Aug 25, 2009 | Lands Phones
Zenith Redi_set clock radio Z230S
Describe your problem: Depress MONTH/DATE and ALARM1 for 3 seconds and display will show DST 'start' month,week,and date.
Display will show 4F 4.1, alternately flashing
4F = April First week. 4.1 = April 1.That is the old dates for change. What we want to do is to change to the new dates. Once it is done, it will change in the new dates as it did on the
old dates..
Hold down the MONTH/DATE button for 5 seconds, and while pressing the - or down button3 times, until the display shows '3'F2.
3 is month F2 is the week.
=March 2nd week.
You have successfully change the March changeover.
Now for the November change.
Depress and hold MONTH/DATE and ALARM2 after 3 second the display will show DST 'end' month,week, and date.
First digit will be 10 =month. second digit will be L=Last week, and date, will flash alternately.
While holding down the MONTH/DATE press the + or UP button once the display will show 11 (November) and F (first week) and 1 as date alternately flashing.
You have successfully set it for the next 100 years
Apr 17, 2009 | Zenith Z230S Clock Radio
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Change home screen display
Press the * key to switch back to date and time. Also, the SHIFT button on top will change the STA EXT FEAT.
The only way I know of changing the name is in the main phone system.
Apr 23, 2008 | Panasonic KX-T7453 Corded Phone
How to change the time on screen
generic for all phones... the standard way to change the time and show it on screen is simply going to the settings and look for time settings... in here, you can actually change the time, the date , and the year and you can also change the time format form 12 hour to 24 hour.
Apr 08, 2008 | Lands Phones
Display Screen Voyage 200
The Solution, which suggests to replace the capacitator seems to be the only permanent.
Turning the device on and of (with "2nd" + "on") rapidly for a few times (about 10-15 for me) made the lines disappear for while, too.
Dec 26, 2007 | Texas Instruments Voyage 200 Calculator
Vodavi Starplus SP7314-08 Corded Phone Logo
655 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
