Question about Brother HL 1240 Printer
Drum light stays on after having replaced the drum unit
Since my drum light was on for a while yet, I decided to replace the drum unit. After having done that following the instructions, the drum warning light is still on. Is there a procedure to put some counter or sensor back to zero or what do I have to do to make it go off?
  • infowis Sep 02, 2008
    Have the same problem and tried the solution of depressing the button until all LEDs were on but didn't fix the problem. Is there another solution? GeoffM.
  • 624 Answers
-Open the printer front door. -Press the recessed button below the row of LEDs and hold down till all of the LEDs turn on. -close the front door. Let us know if you have any more questions and please don?t forget to rate this posting.
Posted on Mar 04, 2007
Thanks for the tip. It worked; the drum light is now off. I couldn't find help in any of the literature that came with my printer.
Posted on May 02, 2007
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
6.Press Options.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
One of the indicator lights stays on
HP LaserJet 2550L Printer panel indicates 4 LED's for 4 toner cartridges, 1LED for the Drum unit. one LED for the power on button. one of the cartridges or the Drum unit has a problem, it indicates from the lights shows on or flashing. By referring to the indication lights you can diagnose the problem contains in one of the cartridges or the drum unit. By replacing the appropriate item you'll be able to make the printer to the working condition.
Jan 24, 2013 | HP LaserJet 2550L Printer
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Drum Error - see routine maintenance chapter in user guide. Do not have user guide
I tried everything and then decided to slightly change the above instructions to:
press Clear/Back
Replace New Drum - select "Yes"
after the screen will show "accepted"
close the front cover and you are good to go
and WA LA it worked!!
Apr 19, 2011 | Brother MFC-7340 All-In-One Laser Printer
Drum light flashing in spite of new drum unit and new toner cartridge
common problem.
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
    Reset the drum counter only when you replaced the drum unit with a new one.
Dec 30, 2009 | Brother HL-2040 Laser Printer
I have a problem with my Ricoh Aficio 2022sp. It leaves a black line when I copy or print anything.
Something around the drum need to be replaced. There are two ways to be done. Because Ricoh do not offer a replacement by parts around the drum unit for this machine by Ricoh you can only replace the hole drum unit. But as you say you have a problem with the drum cleaning blade, or in worse case the drum and the cleaning blade for the drum need to be replaced. So Katun offers a replacement by parts and by Katun is more cheap to be replaced. This is what is the problem, so on your hand is what are you gonna decide.
Dec 23, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Drum light blinks
1. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until
2. The Drum LED continues to blink if the drum counter was not reset when you replaced
the drum.
a. Open the front cover of the printer.
b. Press and hold down the white button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the
button.
c. Close
Dec 10, 2009 | Brother HL-2040 Laser Printer
Beother Hl 2040 printer
f the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Brother HL-2040 Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL 1240 Printer Logo
204 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
