I bought a Whirlpool Washing Machine, Dryer, and Refridgerator from an American base in England. They have a German plug but the lady at the time said I could use them when I return to America. It is now 11 months later and I have returned to America. No one in the area I live in seems to know what I am supposed to do to use these appliances in America. HELP PLEASE!!!!
  • wood_chrissy Dec 11, 2008
    Thank you for your assistance. What if it is not the same voltage and where would I find that information?
    Problem Solver:
  • 17 Answers
Assuming the voltage is the same, you can buy "international wall outlet plug adaptors" in most major cities as well as near most major military bases (because service members routinely return with products from overseas). Simply check your phone directory and/or the internet for "international wall outlet plug adaptors". Also, outlets such as Radio Shack and Brookstone often stock such items.
XMinusOne@gmail.com
Posted on Dec 10, 2008
Whirlpool 6 Sense
I don't have the answer you are looking for but I will tell you I bought a set of Whirlpool Washer & Dryer 9 yrs ago and they were a nightmare. After replacing the boards in both my dryer once and washing machine 2-3 times, I packed them up and got rid of them. If you will start to look you will see all kinds of lawsuits against Whirlpool. Can't believe they are still in business.
Feb 19, 2015 | Whirlpool Cabrio High Efficiency Electric...
My WHirlpool WFS1071BW when turned on keep tripping the fuse.
probably motor short or pump motor short washing machine service man or lady is required
Sep 27, 2014 | Washing Machines
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Plug dryer in wall wont start
The most obvious thing to me is that the cord may have been loosened or damaged by the move, or the terminals in the machine may have loosened. Either test the cord on your "new" machine, or replace it with a known "good" cord. Wait a minute....you already have one of those....
Try it, it may be the very thing!
Regards, --W/D--
Jul 28, 2009 | Whirlpool WED5100SQ Front-Load Electric...
Whirlpool stacker washing machine works dryer doesn't
The problem is probably with the outlet. The washing machine motor is 120 v and the dryer is 220 v. If one pole of the two pole breaker is bad you could end up with the symptoms you have. I have seen this happen before. go to the circuit breaker and push it all the way to off (it may feel like you are crunching something inside...don't worry) then turn it back on and try the dryer. If this doesn't work, unplug the unit and test the outlet with a voltage tester. you should read 220-240 volts across the two slots and 120 volts from each slot to ground. If not, it is time to call an electrician.
Jun 22, 2009 | Dryers
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Top Load Whirlpool washing Machine
Still can have a bad lid switch/ check the plug in connector to the lid switch
Jan 16, 2008 | Tecnik TKL9260 Front Load Washer
Garmin streetpilot C330
maybe you need to go to the settings click on map and click restore. If that does not work click map info and and see if it shows you two different maps. Hope that helps.
Jan 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
