Question about Whirlpool GEW9250 Electric Dryer
The dryer acts as if no electricity is going to it. It shut off
It shut off in middle of cycle. The washer is going fine. No lights it is dead
Is this an electric or gas dryer? If electric, it would be wired seperately from the washer (220V vs 110V) and if so, maybe you tripped a circuit breaker or blew a fuse - that would be the first thing I would check. If you find nothing wrong there, I believe most dryers have an internal overload circuit and if you are not handy, an appliance repairman, or an electrician, I would suggest calling an expert.
If you did trip a circuit breaker and reset it, and it trips again.....better call for service.
Posted on Dec 10, 2008
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Samsung dryer DV218AEB shuts off in middle of dry cycle - "dead" mode
This is a sign of a bad motor. There is an overload protector on the motor that when the motor overheats it shuts the motor down.
May 01, 2012 | Samsung Dryers
Dryer stops in the middle of cycle. It is not the door switch
There's not much here to work with. Is your dryer gas or electric? Do any of your clothes get dry? When you check inside, does if feel like it was warm when it turned off? How long does it run? My first guess would be the cycle timer. But you need to note if the drum was actually spinning and if the heat came on. If so, and everything was normal before it failed I'd go with the timer. If not ,there is another issue like a a safety switch for gas dryers which will not open the gas valve when the glow bar doesn't come up to temperature. Lastly, note where the dial points when it fails and most modern dryers have other cycle dials. Try one of those and see if it stops there too. You might just have a dead spot on the time because that is what you always use.
Apr 22, 2010 | Whirlpool LTE5243D Top Load Stacked...
Dead!! No electrical.Have checked house circuit
check thermal fuse,also see if dryer needs to be cleaned out,clean out lint duct vac out cabinet and go outside and make sure the flapper is opening sometime you need to blow out the vent line,leaf blower works great for this
Nov 07, 2009 | Kenmore 62602 Electric Dryer
Control panel dead
1. Unplug dryer.
2. Remove 2 screws from rear top of dryer.
3. Lift panel assembly up, taking care to not pull wires.
4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
5. Put back together, plug in, turn on.
Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore Electric Dryer 70 Series
your motor is over heating and shutting off.you need new motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Intermintent working
How old is this dryer and does it get slower on heavy loads? Or do you hear a hum when loaded ?
Sep 28, 2008 | Whirlpool LER7646E Dryer
Whirlpool GEW9250 Electric Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
