Wega Mininova EPU Espresso Machine
Problem for Wega Mininova EPU Espresso Machine
What if my coffee does not stay warm?
By Janice - usenet poster
Same Problem
Apr 04, 2008
-   Brand new coffeemaker...on the first use, it brewed a full pot of coffee and then immediately shut off. The instructions for being able to program the auto-off for 1 to 5 hours do NOT work....and the factory setting is supposed to be for two hours, anyway...we didn't even get it to stay on for two minutes after brewing!-   Guest
Feb 02, 2008
-   Brand new coffeemaker...on the first use, it brewed a full pot of coffee and then immediately shut off. The instructions for being able to program the auto-off for 1 to 5 hours do NOT work....and the factory setting is supposed to be for two hours, anyway...we didn't even get it to stay on for two minutes after brewing!-   cklarson
Dec 30, 2007
-   coffee is not hot enough
-   Guest
Nov 25, 2007
-   i have put it in the microwave but it went all icky.-   Guest
Nov 17, 2007
-   Even after warming the carafe prior to brewing, the coffee is luke warm after 1.5 hours. The coffee maker has a heated element and the thermal carafe has rubber feet. Is it safe to leave the carafe on the element after brewing?-   Guest
Best Solution
posted on Feb 08, 2006
Very Helpful)
vicnor
Rank: Apprentice
Rating: 100%, 3 votes
The water heating element is open. Where can I purchase a replacement?
Thanks!
Vic
Was this helpful?
Yes
No
Solution #2
posted on Aug 08, 2005
Somewhat Helpful)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
May be caused by lime buildup. The unit needs to be cleaned.
Make sure auto-off is not activated.
Was this helpful?
Yes
No
Solution #3
posted on Jan 13, 2008
Not Helpful)
Dogtip2
Rank: Apprentice
Rating: 40%, 1 votes
dogtip2 indicated that his solution for
CEMB10TC Problem
is valid for all Coffee and Espresso...
I transfer coffee to a regular thermos. When I am read to drink a cup if not warm enough I put the cup in the microwave (experiment with length of time because that depends on your microwave). The coffee stays good for around a day.
Was this helpful?
Yes
No
Solution #4
posted on Oct 12, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Purchase some good espresso machine descaler at www.cerinicoffee.com.
Solution #5
posted on Jun 09, 2007
Not Rated)
61son
Rank: Apprentice
Rating: 75%, 4 votes
If you have replaced the carafe with another model different than the one specified for it, that might be why. I ran into this problem when my carafe broke. The coffee maker worked fine, however, the thicker pot caused the temp. sensor to shut it off after a few minutes time.
Was this helpful?
Yes
No
Solution #6
posted on Jan 21, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
There is no on off on a plug in Farberware po that I know of. At least not on mine.
Popular Solutions for Wega Mininova EPU Espresso
Questions and Unsolved Problems for Wega Mininova EPU Espresso
Do you recommend Wega Mininova EPU Espresso Machine?
Answer
Answer
Looking to buy part number 4765. Who is the cheapest to get this part from. Zip code is 11790
Answer
how do I hook up reservior? No longer have it plumbed into wall.
Answer
Hi, I have a older black and decker spacemaker coffee maker odc150 and I need parts black and decker... (More)
Answer
is there a video that shows how to install a black and decker spacemaker coffee pot
Answer
what I will install in www.mininova.org if other downloads are have a problem...
Describe your Coffee and Espresso... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
in Van Nuys, CA
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
