Question about Philips Magnavox 55P9271 55" Rear Projection Television
I have a 10 year old phillips magnovox 55 inch tv
When i first turn in on the screen shrinks on all sides and is blurry but after 15 minutes it is fine what is wrong with it?
  • Philips Master
  • 3,459 Answers
Common problem and fairly easy to fix.
Problem
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Solution:
Check with the site www.TvRepairKits.com. They have built a kit to fix this problem.
Posted on Dec 20, 2008
  • 60 Answers
Yes you can take off the cover but carefuly and in the back of your tv you will see the flyback and has 2 button one fro focus and other G2 then rotate the focus button till you will see no blurry
that is all if you dont know how bring some frend who can and tell him to do that
Posted on Dec 10, 2008
Samsung TV turns itself off every 10/15 minutes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jul 20, 2010 | Samsung TXM3297HF 32" TV
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
60" Projection - Screen shrinks down then back up
I had the exact same problem. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 19, 2008 | Philips Magnavox 55P9271 55" Rear...
Problem solved.
I had the exact same problem with my Magnavox TV. The screen would shrink then expand. After thrity minutes it would correct itself. Then one day it just broke - no sound and no video. I searched these forums but did not find clear instructions on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.  To help others like me I documented the fix and created a step by quide and repair kit to fix the problem. You can find it here. http://www.magnavoxhelp.com
Jan 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
After power on TV the screen shrinks to (50%) and then back out to (100%) back and forth for about 15 minutes
the quetion is:  have you checked your format/aspect settings? if it is on auto-format, picture size will vary due to program you are watching.....or is it a raster/width problem? The thing about the time on digital clocks: daylite saving time usually started last saturday, the federal goverment changed it, the fall back time is now this saturday! Most newer digital clocks auto-change according to old schedule....( not sure if you were aware of this )  let us know whether a width problem or what......
Oct 30, 2007 | Philips 9P5544C 55" Rear Projection...
Phillips 60 inch projection tv
you can ask a good tv Technion man, since if it happens to be like that then in coming day u will have to face problems. So since this very common problem which will arise in old tv. Actually the real problem is that, some parts in the board may have become weak or the molded part in the board may have fallen down ,so changing that particular part or molding again may fix that problem. Since i am not an Technion I don't the right terms to help u.I have see this problem in many places and don't worry your picture tube is well and good.
Aug 10, 2007 | Philips 9P5544C 55" Rear Projection...
Help please
I had the same issue. The screen would shrink and then expand over and over. After thrity minutes it would correct itself.
After a few months of doing this it just broke - no sound and no videe but the power light was still on.
I searched these forums but did not find clear instructions or kits on how to fix it. I gave up and called in a repair tech. He fixed my TV in less than 30 minutes.
To help others I documented the fix and created a repair kit and step by step quide on how to fix the problem. You can find it here. http://www.magnavoxhelp.com
May 13, 2007 | Philips 9P5031C TV
Philips Magnavox 55P9271 55" Rear Projection Television Logo
139 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
