Question about Nikon D40x Digital Camera
I have a zoom lens attached to the body. I dropped the camera onto the ground. Now the lens release will not work.
    Novelist:
  • 150 Answers
Sorry, it will require service repair. Contact your local photo shop, go back to where you bought it and have them help you with service warranty, or contact Nikon directly for service support.
Posted on Jan 21, 2009
Hi have a panasonic gx7been given 2 sigma lenses can i fit to my camera 1 x sigma 1:4.5 F=100 - 200mlti coated zoom lens 1 x sigma mini wide 1:2.8 f=28mm multi coated lens thank you
It depends totally on whether your camera takes interchangeable lenses, and if so, do these lenses have the same fitting ? Your camera manual should tell you if you can fit other lenses to the body - if so, follow the steps to remove the lens which is currently attached, and compare the fitments with this lens and the two others you have been given. If you are still not sure, then take it all to your local friendly camera dealer, who will be able to advise you. Do NOT try to force the new lenses onto the body - this is a sure way to render them inoperable.
Dec 22, 2016 | Sigma Cameras
My opteka zoom lens is not recognized by my Nikon d300
First, make sure that you have the right adapter to couple this lens to your Nikon. A universal adapter may actually fit and properly click into place but the electrical contacts may not match your Nikon. Make sure the electrical contacts on the adapter match the contacts on the camera body.
If they don't match, get an adapter specifically for Nikon and perhaps, specifically for your camera.
Once you have verified that it is a Nikon adapter, you need to make sure the electrical contacts between the adapter and the camera body are clean. Many people clean the contacts by holding the lens release button down and twisting the lens or in this case, the adapter, on and off ten or more times.
If neither of these options work you may need to contact Opteka, Nikon or both.
May 02, 2014 | Opteka 500mm f/8 Telephoto Lens fr Nikon...
I have an Infocus LP70. My question/problem is in regards to the lens. I dropped the projector from about a foot off the carpet and onto the lens. The focus/zoom became jammed together, AND the lens came...
What I would try to do is, loosen the screw so its not stiff to adjust, adjust the lens to the right position then tighten up the screw again. Hopefully this should work for you!!
Nov 03, 2013 | ASK Proxima InFocus LP70, LP70+ and...
Dropped Canon EFS lens now makes clicking sound when zooming in and out
Take it to a repair facility, but it may be expensive
May 26, 2017 | Canon Cameras
I dropped my Nikon d50 and now when I turn it on it flashes fEE. Whats wrong?
The lens is not making proper contact with the camera. Try removing the lens, cleaning the contacts on both the back of the lens and in the lens mount on the body, then reattaching the lens. If that doesn't do it, try jiggling the lens gently. If that doesn't do it, try attaching a different lens if you have one available, or attaching the lens to a different body if that is possible. If nothing works then it could be that the lens and/or camera needs servicing after the drop.
Apr 25, 2010 | Nikon D50 Digital Camera
AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
AV error whn pentax ist DL & Quantaray zoom lens attached
I've got the same problem. The problem is that the lense is loosely attached to the body. What you need to do is that when you see the Av flashing, press the lense of the camera to the body and twist the lense to the left a bit. This tightens the connection. You can then take the photo.
Nikon AF 35-135 lens
Did the only the lens drop or was the lens attached to the camera body? If the lens was attached to the camera, you need to verify that the problem is in fact the lens and not the camera body. The easiest way to do that is to try a different lens on your camera body or your lens on a different body. If you do not have access to either, I would find a local camera store that sells Nikon equipment. I am sure they will let you put your lens on one of there bodies. In any case, ff the damage is as extensive as it sounds from your brief description, you need to take it to a camera repair man. This is not a do-it-yourself job.
Feb 07, 2009 | Nikon N70 35mm SLR Camera
Canon 20d - lens stuck / jammed
HI BRIAN ,,I AM SAGHA CAMERA REPAIRER,I THINK UR PROBLEM OCCURS DUE TO JAMMING OF PLASTIC MOUNT ON THE METAL BODY OF 20D.TRY THIS
1} LUBRICATE THE JUNCTION WHERE LENS GET ATTACHED TO THE BODY WITH KEROSENE THEN TRY TO RELEASE THE LENS.REMOVE THE BATTERY FROM CAMERA ,TRY AND HEAT UP THE JUNCTION WITH HAIR DRYER A LITTLEBIT THEN TRY TO RELEASE THE LENS.
2}IF THIS THING ALSO DOESN'T WORK THEN YOU HAVE TO SACRIFICE THE LENS PLASTIC MOUNT PUT SOME SHARP KNIFE LIKE OBJECT IN THE JUNCTION OF LENS & CAMERA & THEN PUSH IT UPWARDS WHICH WILL BREAK ONE OF THE PLASTIC LENS MOUNT COLLOR AND LENS WILL COME OUT WITHOUT DAMAGING YOUR CAMERA .LATER YOU CAN GET REPLACED THE LENS MOUNT FROM SERVICE PERSON. BUT NOW ATLEAST YOU CAN USE CAMERA WITH OTHER LENSES.
Sep 29, 2008 | Canon EOS-20D Digital Camera
I dropped my EOS Digital camera and 300 MM Zoom lense in the river. The camera has dried and seem to be workin gfine, but the zoom lense needs to be cleaned.
Dear catnip54,
You could obviously clean the front and back elements on the lens(use a microfiber lens cleaning cloth), but there is no way of cleaning the inside of a SLR zoom lens other than having an authorized service technician take it apart and clean each lens element seperately(which could be expensive). I would count myself very lucky that your camera body still works after being immersed in water.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Apr 18, 2008 | Cameras
Nikon D40x Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
