Question about Canon EOS 400D / Rebel XTi Digital Camera
Need to reset settings
Can't get AWB or MF Off the camera, lost manual all pictures blurry
Hit the menu button, hit jump until you get to the last tab..."clear settings" and either hit clear all custom functions or clear all camera settings. Your dial might have to be on "P" for the last menu option to come up.
Posted on Dec 11, 2008
Camera takes blurry pictures up close and sharper ones from afar. Camera will not focus on specific object either.
There is a "close focus" limit, depending on your lens. The standard "kit lens" won't focus closer than about 2 feet away. Check that the switch on the lens is set to "AF" not "MF" "MF" means, "manual focus".
When you lightly press the shutter button, the viewfinder should blink with little dots/squares indicating what it focused on, and beep. If it doesn't, and you are set for "AF", then your camera needs repair.
May 10, 2015 | Canon EOS 600D Rebel T3i Digital Camera
I have a EOS Rebel XS camera with a 18-55mm lens. Every time I try to zoom in both lens and the picture are blurry. Am I just in the wrong settings?
make sure the lens is not in manual mode. on the side there is MF and AF make sure its in AF for auto focus. id its still looking nblurr in the viewfinder when pressing the shutter half way then user the smal wheel next to the viewfinder so the viewfinder is calibrated for your eye.
Feb 05, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My son has a Fujifilm S1000fd and when I get the pictures printed, there is a yellow hue in the photo, how can I fix it?
Color setting on the camera. Is it set to Auto White Balance (AWB)? Daylight? Fluorescent Lights? Flash? Cloudy Day? It's best to set it on AWB.
Sep 07, 2009 | Fuji FinePix S1000FD Digital Camera
Blurry pictures
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
Also try to reset the camera back to factory defaults as there could be a setting that is causing the images to be blurry. To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset and press ok. Highlight yes and press ok. This will reset the camera back to factory settings. See if this clears up the blurry images.
May 03, 2009 | Olympus SP-560 UZ Digital Camera
Canon 20D strong blue cast to pictures
You probably have the White Balance set to a setting other a
than "Auto White Balance" (AWB). On the top of the camera, above the exterior LCD panel, there is the "AF-WB" button. Turn the camera on--past "on" to the bent line. Press the AF-WB button once. On the left side of the exterior LCD panel there is a vertical, reticular box with the symbol of the selected setting for WB. Normally, the setting should be set to AWB. If it is not, turn the command dial at the back of the camera until "AWB" is showing. Try shooting again-the color should be better.
In the "auto" modes (green box, portrait, landscape, etc) the AWB is automatically set. In the "advanced" modes (P,Tv, etc) the WB is manually set for whatever light source you are using. The command dial may have been accidently turned to different setting. Hope this helps.
Jan 23, 2008 | Canon EOS-20D Body only Digital Camera
Picture taking
Hi , need a flush , set camera to flush navigate press auto or flush sign.
set camera in manual , press function set , navigate to awb an auto , set icon flourescent press function set , then okey
Dec 14, 2007 | Cobra Digital DC6550 Digital Camera
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
AWB problem on 555
I noted that situation, but was my fault because i've been using Bulb or tungsten in outdoor pictures...!!! AWB works fine most of the cases except in some indoors where i have to use manual WB. Please be aware that if you have enough indoor light could be a good idea to disable the flash, try and error......
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
130 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
