Question about Acer Aspire 3610 Notebook
Inverter How do you determine which inverter is compatable with screen,motherboard,etc.
    President:
  • 1,073 Answers
By reading the manual, or getting the information from the product site
Posted on Dec 10, 2008
  • 60 Answers
You need to take that old out and you will see on it some serials and models
I bought a used motherboard from ebay.After a month it turned black screen again so can u help me
So you replaced the motherboard.
Well the systems are like laptops so you need to check LCD cable inverter and the LCD screen.
eres one that had a motherboard problem but the screen seems ok.GATEWAY ZX4300 01E ALL IN ONE AS IS FOR PARTS <<< i buy part as is when it system don't power up because its not screen related.
or pay seperate
Gateway All in One ZX4300 41 Inverter Board
Gateway All in One ZX4300 41 Inverter Board Cable DD0EL2IV000
Gateway All in One ZX4300 LCD Video Cable DDEL2CLC000
check if the system is compatible.
May 13, 2014 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Tip
How to solve the problem of Dark Screen of Laptop
To solving the problem of Dark Screen of Laptop there are a few things to determine to see what the problem is. <br /> The first thing I would advise to be done is to check your laptop with an external monitor to make sure that it is not the video chip that went bad. So connect your laptop to an external monitor and see if you get a picture (you might have to press the fn and one of the f1 , f2 , f3 etc....keys together to switch the output to an external display , If you get a picture on the external monitor you know it is not the motherboard , (whew, was getting scared already). If you don't get a picture on the external monitor make sure it is plugged in correctly and that you pressed the correct keys to have the output signal go to the external monitor. If you are sure you did all of the above steps correctly , then shut off the computer and try pressing down on the keyboard while powering up the laptop and see if you get an image. Sometimes if a computer has a loose connection between the GPU (Graphic Processing Unit) and the motherboard it will result in no video or flaky video , so try pressing down on the keyboard while powering on and try see if you get video. If you get a video output then you will know that it is a flaky video chip and that will have to be fixed. <br /> Inverter is usually at the bottom of the screen. Now back to if you got a picture on an external display. Once you got a picture on the external monitor and established that it is not the video chip or motherboard you will have to try to determine if it is the lcd screen itself or if it is the inverter. The inverter is a small electronic board that controls the voltage that is sent to the backlight (the light bulb of the laptop screen) of the lcd screen. If the inverter breaks or dies then no voltage gets to the backlight resulting in no video output signal to the display. In my experience, I see that most of the times it is the inverter that is the problem and that is a pretty easy fix , you just have to get the correct inverter that supplies the right amount of voltage and you will be back in business. But in some instances it is the backlight (light bulb) that went , and to repair this is more difficult and more time consuming. One way to see if it is the inverter , is to test the two prongs of the inverter with a voltage meter and see if they are giving off the correct voltage (please read up more on this method , as inverters have high voltage output , so you have to know what you are doing , so I strongly advise to read up on this more prior to doing it. Another simpler way is to shine a flashlight on the lcd , if you see a faint image then in most cases it is the backlight that needs to be replaced. If you don't see an image even when shining the flashlight then it is most likely the inverter and it should be an easy fix. <br /> <br /> On a last note if you determined that it is the backlight that is faulty , although it is fixable it requires more time and experience then just replacing the inverter , and if one is not experienced you can damage the lcd screen itself as well , so generally if the backlight is faulty either have a laptop repair shop replace the backlight , but only one who has experience. Or another option is to buy a new lcd panel and install it either yourself or proffesionally. Generally it is not very difficult to replace a lcd panel but there are some models that are more difficult so try to ask a laptop repair shop about your specific model <br /> <br /> <br />
on Jan 01, 2011 | Computers & Internet
LCD screen flickering
Display Configuration A flickering screen may be caused by the computer detecting incorrect display settings as it starts or returns from sleep. It can also come from changes to the screen resolution settings caused by a new program or update installation. Verify screen resolution before assuming the issue is hardware related. Faulty Inverter Next to the display screen behind the plastic screen bezel is a small component called the inverter, which supplies power to the screen backlight. The flickering indicates the power is not reaching the backlight. To fix the issue, replace the inverter. Faulty Connectors The wires and cables traveling from the display around the hinges and into the motherboard tend to wear at the hinge area. Over time, the opening and closing of the screen causes this wear. The solution is to disassemble the plastic casing of the laptop, reorganize the cables so they have no interference from hinges, or replace the cables and connectors with new ones made specifically for the computer make and model experiencing the issue. b> Test an LCD Inverter An inverter is an electrical device on the bottom of your laptop screen. The job of the inverter is to convert DC electrical current to AC voltage to maintain power to the backlight lamp. If the display on your laptop is dark but working, odds are the inverter or the lamp are at fault. When troubleshooting monitor problems on a laptop, you may need to evaluate the inverter to determine which of the two parts is malfunctioning.
Remove the screen bezel on your laptop. The bezel is the piece of the computer casing that surrounds and protects the LCD screen. To remove the bezel, remove the screws around the screen. Bezel removal method may vary by model. Once the screws come out, the bezel should pop off. The inverter will be under the screen. Attach the positive probe (+) of a multimeter to the pin 1 on the inverter. The inverter has two connections, one on each end. With the laptop screen facing you, look at the left side of the inverter. Pin 1 is the top metal flange pointing to the right. Secure the negative probe (-) of the multimeter to any bare screw. There should be a screw securing the inverter to the laptop that will be perfect for the negative ground connection. Turn the laptop on to test the inverter. Turn the multimeter on and check the multimeter reading. If the display records voltage going to the inverter, such as 19 V DC, the inverter power supply is working. Turn the laptop off. Unplug the LCD inverter connection on the right side of the inverter. This disconnects the backlight from the inverter. Plug a working backlight to the connection on the right side of the inverter. Turn on the laptop. If the screen lights up, the backlight lamp is bad but the inverter works. If the screen remains dark, the inverter is bad.
Feb 25, 2013 | HP Pavilion Computers & Internet
Laptop, display problem
Dear User..Does the Screen have a displayed Image?
If the laptop has no image at all it can be video card or LCD cable or the LCD panel. About the only non-invasive test you can try is to plug an external monitor into the laptop. This will determine if the problem is motherboard/graphics card or lcd cable/lcd screen. If you have an image on the external monitor then its likely to be lcd/cable/lcd screen.
Is the Displayed Image Faint?
A dim screen can be caused by three things;
1/ The LCD inverter which runs the LCD backlighting
2/ The CCFL backlighting fluro tube in the LCD panel
3/ The motherboard supplying signal & voltage to the inverter.
Thanks
Jan 30, 2013 | Computers & Internet
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
PACKARD BELL EASYNOTE SJ51. NO INVERTER VOLTAGE. ALL LEDS OK, SOUND OK, BOOTS OK, SCREEN BLACK OR POSSIBLY DIM.
Simple test: get a flashlight, go with the laptop in a dark room and point the flash light at the screen. If you see the image then indeed the inverter isn't working. of you don't see it then the data cable between the motherboard and the screen has been damaged: replace it.
If the inverter is at fault you will need to open the screen cover and check if the inverter board receives power from the motherboard: if it does you need a new inverter board
http://sparepartworld.com/display-inverter-board-for-packard-bell-easynote-sj51/product_info.php/products_id/1724545
If it doesn't then a complete testing of the motherboard will have to take place to find out why and if it can be fixed.
Aug 12, 2011 | Computers & Internet
My laptop screen is blank when i push the on button,the screen is blank but the lamp for the screen is on,what is my laptop problem?tq
Hello
Hope this helps if so do rate the solution
Jan 02, 2011 | Acer Aspire 4520-5582 Notebook
When started all i get is a dark screen
Hello
Hope this helps, if so do rate the solution
Jan 01, 2011 | IBM ThinkPad T43 Notebook
Only power on in lcd.no disply and etc
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Jun 14, 2010 | IBM ThinkPad T30 2366 Notebook
Dell Inspiron B130 was black when turned on. Holding flashlight to screen, could see desktop and all icons. Was able to open programs, etc., while looking with flashlight. Replaced LCD Inverter listed for...
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Dell Inspiron B130 Notebook
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
