Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag atlantis water does not stop filling, replaced timer and switch
  • max_horton Feb 20, 2009
    My Maytag Atlantis has a strange problem I can’t figure out. When I start the washer it runs fine until it gets to the rinse cycle. Once in the rinse cycle is just fills and drains the water at the same time. It will continue to do this until I stop it. It does the every time. I have replaced the timer and water level selector and hose. Sometimes it also does this when I first start the washer. I will start the washer, the tub will fill with water and then drain it. Sometimes it won’t even fill because it drains the water as it enters the tub. Any ideas?? Thanks.
Machine stopped in the middle of a wash cycle,6 days later waiting on best buys geek squad to come service(cancelled that with a bad taste) now its been 6 days not running I decide to turn dial to show my son the problem wah la it worked wash to normal loads with gratitude and during my 3rd load it froze again I read up etc went to my breaker box threw it and lo and behold it worked then stopped mid wash again i smell a faint burning smell I have had the lid switch replaced 6 yr & it still clicks a belt was replaced and then 1 month after belt trans went and replaced. I feel its in the panel cause ofg tricy play with my home receptacle box work dont work tactic any advic out there
Posted on Jul 13, 2010
  • dma295386 Jul 13, 2010
    dma forgot to note I own a maytag atlantis 600
    my macine is doing this in wash cycle does that matter
  • 4 Answers
Check the host that attaches to the water level sensor. The sensor is located behind the water level setting dealy ( I forget what they call it) so you have to remove the control panel to get it. Before you do that you can see if the tube is connected properly by just opening up the top of the washer and pulling on the tube. If it comes down in your hand there's your problem. If you can't pull it out it still may be connected but have a hole in it or just not be completely secured. You will have remove the control panel to fully inspect it.
Posted on Jan 16, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I have a maytag atlantis washer that will completely fill at the beginning of the cycle, stop, then make a very loud squeeling noise, stop, and now will not advance through any cycle...even manually. We...
The not completly filling and squeeling makes me want to look at the screen on the water valve that the hoses attach to on the rear of the machine for blockage preventing water flow,to me the squeeling is the solonoids on the water valve calling for water yet no water coming in. IF you manually fill the washer using buckets of water/a hose what will happen? perhaps try that!!
Also if you have the "aquaflow flood stop" hoses the internal stopper in the hose is bad,replace hoses using standard hoses
Good luck,i hope this helps you to fix your washer,
Gene
Aug 09, 2011 | Maytag Atlantis MAV9501E Top Load Washer
Washer is over filling.
Hi, Does water enter the machine when there timer is off or even if the machine is unplugged? If this is the case, the inlet valve needs replaced. If the water stops when the timer is turned off, there is a problem with the water level switch. Please let me know so that I can assist you further. Thanks
Vic
May 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis top-load washer won't fill with water, no power.
Not the lid switch>>>The water level switch ...unless you have forgot to turn the water on,Please Rate This !!!!
Dec 01, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
My maytag washer just stopped working...
Manually open the timer switch component rotate the knob forward and it will work. / rotate inline w/water fill full keep near the timer you can hear the timer running or not / if not the small motor of timer need to replace availqble in appliance service center,.
Dec 16, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Timer on maytag Atlantis
replace water inlet solenoid first if this doesnt work replace timer
Dec 08, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis wont run
JC, sounds like the lid switch, check this first and post back..Catriver
Oct 30, 2006 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
