Question about Encore Family Tree Maker 2005 for PC
"too many book items"
When trying to merge/append a file into another I keep getting operation failure due to too many book items, but there are no book items at all. I tried creating new files in case the software was "remembering" previous versions of a file where there were books. It's REALLY annoying. Any ideas? Thanks
    Problem Solver:
  • 18 Answers
Check the manufacturers website and make sure that there are no updates for your software. Also, you could try copying smaller bits of information into files, then try to merge them over... I cant find where you would even find technical support information let alone an update. :/ Other then that, theres nothing else I can think of.
Posted on Sep 20, 2007
SOURCE:
Can I Merge Multiple Outlook PST Files into a Single File?
Merge PST tool is the best option to merge multiple files as it is highly used by my organization from last 3 years and we got excellent results from this software. There is an option to exclude deleted emails from merging into resultant PST file. http://www.datavare.com/software/outlook-pst-merge-expert.html
Install Outlook PST Merge Expert
Apr 21, 2018 | Computers & Internet
Tip
How to merge two emails in Lotus Notes?
Due to the extensive usability of Lotus Notes, multiple NSF files get increases enormously. Hence it creates a lot of chaos to handle multiple NSF files effortlessly. This leads to unmanageability and the problem of mishandling, the Lotus notes file can corrupt or damage NSF files. Therefore, by merging Lotus Notes email files into one, makes it easy to handle.
To Merge NSF file manually into one
We are aware of that manual processes are the quite lengthy procedure. But it's free of cost, i.e. no cost associated with it. But when it comes to giving an answer for "How to merge two emails in lotus notes" This is the best reply and good for the coders who loves coding.
*First, you need to create an archive. And then, you can archive all other NSF database files into it one by one.
Note: Before you can try this manual trick, make sure you take the backup of your original NSF database files just to play safe.
Now follow the below-mentioned steps for merging NSF files into one.
Step1: Create an archive replica so that you can move the database contents.
Click the File > Replication > New Replica
Now click the Browse button to define file path and name.
Click OK.
Wait for a bit till it gets successfully completed.
Step 2:
Choose the NSF database file from which you want to move the data.
Step 3: On the taskbar, Click File > Application > Properties
Click on Archive Settings to create a new setting.
Step 4: On the Archive Settings dialog box, click the Criteria tab.
And then, click on Create.
Step 5: In Create Archive Criteria dialog box, give a name to this new criteria.
Click the Selection Criteria.
Step 6: On the Archive Selection Criteria dialog box, define the options.
Click OK.
Step 7: Now check the Enable this criteria box.
Under what should happen to the Selected Documents section, click the Browse button to choose the archive database into which you want to move the data.
Click OK.
Important note
·Make sure the archive file and the NSF database files should have a similar folder structure.
·If there are different folders in the NSF database files, you need to create a new folder in the archive database of the same name.
·Double-check the archive before you close the window.
This task may get tedious if you are having plenty of NSF files and folder and a lot of content. Then the third-party applications can help you complete your task in an easy and secure way. NSF Merge Tool, inbuilt with many smart features which can easily merge multiple NSF files and folder easily also, it's demo version is available totally free of cost. This is the ultimate answer to the query- "How to merge two emails in lotus notes"
NSF Merge Software
on Mar 16, 2018 | Miscellaneous
When installing windows xp, the C: drive got partioned and formed a new drive named F:, now i want to merge these two drives due to low disk space , can you tell me how to merge that two drive into one .
Hi
When you attempt you reinstall the windows operating system and you are in the WINDOWS XP SET UP, there is an option there to delete the partition.
Another option is by going to COMPUTER MANAGEMENT. Just right click mouse on MY COMPUTER ICON, click on MANAGE, click on DISK MANAGEMENT, now right click on DRIVE YOU WANT TO DELETE and there is an option to DELETE THE VOLUME. Be sure you back up your files coz it will wipe all your files there.
I hopw it helps you.Regards
Mar 25, 2011 | Computers & Internet
We have a script which generates CSV file from DOS based paradox 4.0 table. Please let me know if there a way to get the report with table column description as the first row with the report generation.
What scripting language are you using?
In general, I'd say it wouldn't be hard, generically, you could parse the query and/or results to get the description.
Alternately, if your reports always use the same fields in the same order, simply write the headers to a file then append the results of your query (append instead of write).
Aug 29, 2010 | Computers & Internet
Create batch file
Did you try the following?
  1. Open all of the workbooks that contain the scenarios you want to merge.
  2. Switch to the worksheet where you want to merge the scenarios.
  3. On the Tools menu, click Scenarios.
  4. Click Merge.
  5. In the Book box, click a workbook name.
  6. In the Sheet box, click the name of a worksheet that contains the scenarios you want to merge, and then click OK.
  7. Repeat this process if you want to merge scenarios from more worksheets.
Feb 21, 2009 | Microsoft Office Standard for PC
I have duplicate accounts for Colorado Unemployment Taxes
Are they named the same or is there a 1 or some other variation for the extra account.
You cannot merge payroll items, the only thing that you can do is to make sure you have all employees using the same payroll item, Do a payroll adjustment to move any balances over to the proper payroll item and then make the extra account inactive.
This will take you to one and let you run set up
Jan 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Encore Family Tree Maker 2005 for PC Logo
94 people viewed this question
Top Encore Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
