Question about Brother HL 5150D Laser Printer
Brother HL5150 D printer. PF Kit 1 shows zero left available, and I need to reset teh counter for PF Kit 1
  • 552 Answers
Go here by copying and pasting this link
 http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000026/faq000026_004.html?reg=us&c=us&lang=en&prod=hl5150d_all&Cat=4
 to see the visual aids for your machine at Brother Printer solutions center.
The website mentions that the use of the wrong type of paper could cause this problem.
Posted on Dec 10, 2008
Message reads "Replace PF Kit" but everything is working fine. Is this an error and if so, how do I clear it??
The PF kit has life expectancy, if everything works fine just reset its counter.
Press "3 & 9" together, select the desired parts counter reset.
Aug 19, 2014 | Brother MFC-9320CW Color Laser Printer -...
HL-5250 report shows fuser and laser life at 0% and PF kit 1 at 12%
The fuser is a separate component to the drum and toner in this printer. It has a much longer life than them but will run out eventually. Sadly a fuser unit is not a commercially available consumable for this printer either. I would recommend contatcing a printer technicain or Brother directly for a quote on replacing this part.
Apr 12, 2013 | Brother HL 5250DN Laser Printer
OK, we've got a second-hand brother 6050dn for our computer lab of about 35 computers. I've recently replaced the PF KIT For the MP drawer, but had trouble resetting it. Finally figured it out...
Replace the parts! If it is used you have no idea of how old the parts in it are even if they look good. The counters that turn these messages count sheets of paper not time and the parts may have moisture damage from sitting up.
May 02, 2017 | Brother HL-6050DN Laser Printer
I need to replace "PF
Ah the Paper Feed Kit 1 on this unit is pretty easy,
If you remove the paper tray and put the printer on it's back you should see the rollers you're going to replace.. unfortunately the service manual doesn't show this procedure so I can't provide a picture.
If memory serves correctly there should be a long light-blue plastic piece that holds the PF Kit roller assembly in place. If you bend this towards the back of the machine the PF Kit should swing down and you just slide it out, replacement is the reverse of this.
Once you're done you'll have to reset the PF Kit counter by:
Press GO and + together,
you should see RESET PARTS LIFE on the LCD
You can then use the + / - to pick the PF Kit and press the SET key to reset the counter.
If you still have problems let me know via this question and I'll try to help further.
Jun 10, 2011 | Brother HL 5250DN Laser Printer
Just replaced the fuser maintenance kit. How do you reset the fuser counter? It still shows 0% left even after turning the printer off.
It all depends on which model printer you have, which you didn't specify. Normally fusers don't need to be reset though. Search the manufacturer's website to see if you can find the manual, which should contain information on how to reset consumable counters.
May 11, 2011 | Office Equipment & Supplies
I am trying to buy a pf kit 1 for my brother MFC 8670 DM. Where can I purchase this?
Just clean the pick up rollers with water + a dash of meths and a drop of detergent, de-fluff the paper separation shoe and rollers on the paper trays. Reset the PF Kit 1 counter (PF = paper feed) and carry on.
Aug 16, 2010 | Brother Office Equipment & Supplies
How to replace the PF roller on a brother DCP 8065
1.Pull out the paper tray
2.turn the machine upside down
3.push the blue lift arm and pull out the pin of the PF roller
4.then slide the PF roller to the left and pull it out
5.replace it with new one put the pin of the new roller into the hole of the blue lift arm.
6. place the machine on its base.
P.S you need reset pf roller counter after replacement
press "MENU - START - 088"
LCD shows "PARTS REPLACEMENT"
go down with arrow till "reset PF kit T1?" PRESS "SET" key
all done.
Jan 31, 2010 | Brother DCP-8065DN Laser Printer
Mfc-9420cn pf-kit2 reset, how to reset the counter after installing new kit
Press Menu/Set, 7, 4. Press down arrow to select PF Kit 2 and press Menu/Set. The confirmation message appears on display PF Kit 2. Press 1 to reset or 2 to cancel. PRESS 1.
Nov 03, 2009 | Office Equipment & Supplies
How do you reset the fuser counter on the 9440CN from Brother
This function is provided for service personnel in order to reset the counter of each periodical replacement part and count the number of replacement times when replacing the periodical replacement parts.
(1) Press the 3 and 9 buttons at the same time in the ready
status.
(2) The “Reset Menu” will appear on the LCD. Select the
applicable periodical replacement part by pressing the up arrow or down arrow button and press the OK button.
< Periodical replacement parts are indicated on the LCD >
- Drum - Belt Unit - PF KitMP - PF Kit1
- PF Kit2 - Fuser - Laser
(3) When the OK button is pressed the “1. Reset 2. Exit”
appears on the LCD. Press the 1 button if resetting the
counter. If not, press the 2 button.
(4) Pressing the 1 button accepts that the machine implements
the counter reset.
(5) If the 2 button is pressed the machine goes back to the
select part counter again. If you need to Exit press the
Stop/Exit button at any time.
(6) The machine returns to the ready status.
Oct 30, 2009 | Brother MFC-9440CN Laser Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Brother HL 5150D Laser Printer Logo
754 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
