Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper jam i have a paper jam so the printer sez but i cant seem to find the paper and i dont know if i should open printer to find it or wot to do plz help
    President:
  • 2,961 Answers
There is normally an access bay at the rear of most printers to check for paper jam, but the printer may need to be disconnected from the pc and reset. If it still shows the same error it may be worth disconnecting again, ununstalling the driver in add/remove programmes then reinstalling and reconnecting in a different USB port if you have a free one.
Posted on Mar 03, 2007
There is a paper jam inside the printer and i dont know where
For some paper jam like this it will be better if you blow air inside your printer and make sure everything is clean and not even a small piece of paper is causing the problem. SO better do check again the inside of the printer and use a flashlight for you to see everything.
Feb 07, 2013 | Samsung ML-1660 Monochrome Laser Printer...
Hello all my epson stylus cx3200 has a paper jam error note. I did all the things wanted by the printer including removing the paper , loading the paper etc but the red lamp is on again. someone told me...
HI,
It is the process for determination by measurement or comparison with standard.
pls follow these steps,
just you switch off the printer and once again connect,
place the paper correctly,and ensure there is no print jobs are in quaue
If so goto printer and faxes and select the default printer
and open it and cancel the tasks.you better select according the
page numbers that you want to print.try with this.
May 26, 2011 | Epson Office Equipment & Supplies
Paper won't load thru tray sez no paper
Open the printer up and try to get the printer in motion. If there's nothing jammed in the printer and it's getting stuck when trying to print, you might have a carriage jam. The second thing that could be causing this is the laser which identifies how large the paper in the tray is. That could be dirty or it could be damaged.
The third thing you should try is a driver update from the Canon website. It could just be a software problem.
If none of these steps work, then it's likely a hardware problem and you will need to call Canon at 1-800-OKCANON
Jan 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My printer won't print because it says that there is a paper jam, but there is no paper left jammed in the printer. I don't know how to solve this considering there is no actual paper jammed in the...
HI,
it seem there was still left paper in yur printer
please open again the cover and look very carefully for the paper
even how small it is it will still cause a paper jam.
after that turn off your printer and try to open it again.
any changes happen let me know.
thanks,
Mar 30, 2009 | Dell 948 All-In-One InkJet Printer
Message paper jam and open left drawer cover
Delay Jam in Delivery Assembly (Paper Leading Edge Jam at Delivery Sensor/Wound Paper Jam at Fixing
Assembly
Mar 19, 2009 | Canon iR 2020i Laser Printer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Paper jam lexmark x3470
#2 works for an x3470, but jostling the small cylinder that accepts the paper (nudge it gently toward the printer) seems to be what pulls back the microswitch...
Oct 16, 2007 | Lexmark X3470 All-In-One InkJet Printer
Paper jam cant fix it
Try for a re-set. See your manual How you do this can be a mystery because every make model it seems is different. If you have several button to press for various actions try this. Turn the printer off- press any two buttons together and whilst they are pressed switch on- holding the buttons down. Now I do not know how many buttons or combinations you can make on this particular machine so it will be a process of elimination. You could also get onto Canon Tech Support team. A useful site is also www.fixyourownprinter.com
Jul 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
