Question about Teac DC-D2831 CD Shelf System
Cd player noise
Cd player makes loud ticking noise while playing;tray opens sluggishly
0 characters
1 Points
Isymphony m1 CD tray won't open
The CD door drive belt has broken. The same has just happened to my iSymphony. I'm now trying to source a new belt
Dec 25, 2012 | iSymphony M1 Shelf System
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
The cd tray doesnt open and the motor doesnt stop making this noise that sounds like its just going and going
Could be the belt for driving the cd tray door has come off one of the pulleys.. I had similar problem with a Marantz CD Player.. I could stop it making a noise by pulling the door out, setting the disc and pushing back in.. THis allowed me to at least play the cd's.. To set the belt onto the pulley wheels I had to dismantle unfortunately.. If you're feeling competent it can be done.
Aug 03, 2011 | RCA RS2652 Shelf System
CD'S wouldn't play or come out
There is a small wole in the tray, you can open the tray by incerting a samal stick inthat wole and then press that causes the tray to open.
Hope this help
Jun 24, 2009 | Sharp XL-MP130 CD Shelf System
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Shelf Systems
CD ticking problem!?
please check the is on five or more rubber mounts one of rhat rubber mount damaged. or is anything stuc inside the player .
if you have warranty go with problem occurd cd and sho it to them.
they have to fix it .isnt it?
Jan 14, 2009 | Teac Audio Shelf Systems
My XL-MP130 stereo makes a racket...
What your machine is doing is... whenever the unit is powered on or off the cd player resets itself and the clanking you hear is the cd changer resetting itself.  The plastic trays of the cd player are driven by plastic gears.  These gears are noisy when new, after a few years, they can make quite a clanking noise.  Most cd changers of this age have similar mechanisms and this type of noise is inherent in their operation.      I'm afraid the only solution is to replace the unit.  Opening the unit to lubricate the gears may cause more problems than it may solve, so I would not recommend it.
Jan 02, 2009 | Sharp XL-MP130 CD Shelf System
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
Every disc in tray ends with noise after a minute
Try a cd cleaning disc, the ones you can buy with the small cleaning brushes on them! It sounds like the laser is dirty.
Sep 13, 2007 | RCA RS2640 CD Shelf System
Something spinning
1. Check all cable connections to make sure they're secure. 2. Replace the cable connecting the CD unit to your receiver. 3. Clean the contacts on the player and receiver with electronics-grade contact cleaner. good luck
Jan 06, 2006 | RCA RS2041 CD Shelf System
Teac DC-D2831 CD Shelf System Logo
620 people viewed this question
Top Teac Audio Shelf Systems Experts
John Trigg
Are you a Teac Audio Shelf System Expert? Answer questions, earn points and help others
