Question about HP Office Equipment & Supplies
Project not printing when i put in card paper, but does print with copy paper, stops before finished, and error comes up
  • 479 Answers
The printer gears becomeming tight due to thick ness of the card not use it as it will damage the printer paper pickup assembly.
Posted on Dec 10, 2008
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
How to put C460FW Samsung printer in "tech Mode"
(From ready to copy/Just finished warming up from power off)
Press the following buttons in order
Menu, Back, Left arrow, Right arrow, OK, Stop/Clear, Menu
Sep 01, 2014 | Samsung Xpress SL-C460FW Laser...
When I try to line tells me that the paper size mismatch and only takes a copy of the text
Have/had the same problem: Getting "paper size mismatch" on the C4280 status screen, after we got a paper jam. Every time we hit OK and put in paper, Message about "Now printing Alignment page", it feeds through quickly, with nothing printed on the page and reverts back to Paper size mismatch. Finally got rid of the error, not sure how, but now when I try to copy anything, we only get the lower right postion of the document that I'm trying to copy. Printing from the PC seems ok.
Powered off and back on, and it is back to P"now printing alignment page, quick feed through and "paper size mismatch" error. AND
When copying directly from the glass panel,it will only print a quarter of the page -however it prints and coorectly if we print directly from the computer.
The problem is the paper size sensors. Remove the plastic access panel that is for access to the rollers in the back and has 4 rollers on it. There are two papaer sensors attached to the printer circuit board (PCB). The control arm for the sensor is a small plastic piece that extends slightly into the paper path above the PCB. The plastic can be broken when you are removing a paper jam. I stuck a small piece of a match stick in the sensor to keep it open (as though a wider piece of paper was passing throught the printer). I can't switch to smaller card stock, etc, but who cares, it works.
The copying problem is caused because the C4280 will not scan correctly until after it does the alignment phase.
Dec 16, 2010 | HP PhotoSmart C4280 Laser Printer
I just paid a tech to come out because the printer stopped printing (the pages were coming out blank) I purchased new toner; but that didn't fix the problem. The Tech came out and said he just had to...
I suggest you remove the toner cartridge, take it outside and holding it away from you shake it back and forth a few times. Reinstall it and try printing.
Sep 21, 2009 | Office Equipment & Supplies
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Copier stops after 35 copies when using finisher
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Jun 02, 2009 | Canon imageRUNNER 400S Copier
Double sided copying
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Print and copy comes out blank paper
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Ben Johnson
