Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
1/2 hp craftsman garage door opener won't open when cold
It works fine when its warm, but the colder it gets the less it travels up. If I help lift it will travel all the way up. Sincerely Jerry ps it goes down fine
  • Anonymous Dec 10, 2008
    We too had same problem. I inspected all roller wheels and found one loose and mis-aligned. I re-aligned it and tighted it back up. Also i sprayed the rollers and track with silicone spray. It seem to help. Bud in Az.
I called Sears garage door customer service number due to the same issue. The test is to disengage the opener drive by pulling the emergency disengage handle, then open the door half way manually and then let it go. If it stays there it is a door/track/lub problem; if it drops down and closes its a garage door opener problem. Mine stayed open half way during this test so it was a door/track/lub problem. After using silicone spray on all tracks, rollers, and springs mine has been working great. Good luck.........
Posted on Dec 19, 2008
I had the same problem a few years ago. I adjusted the "Up Force" knob at the back of the unit towards High.
Posted on Dec 21, 2008
My Craftsman garage door opener opens fine. It
It could be closing too far or the sensitivity could be set too sensitive.
Lube the springs, wd-40 rust may be the whole problem.
If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
Hope this helps.
Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Our Craftsman model 139.5364 works fine when it is warm, but not when it is cold. Even right after a brand new warm battery is installed. How can we get it to work when cold ?
Some electronic components become sensitive to temperature and the only fix is to isolate the component and replacing it. In the case of door opener remotes it is cost effective to replace them.
Jan 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close by remote in cold weather
There are ususally two adjustments on garage door openers...
One is for the pressure and the other is for the travel. Assuming that the travel adjustment is properly adjusted...
On a cold day things are a little tighter and it "wants" a little more downwards pressure to complete its cycle. Sorta like me in the morning -- I need a little coffee to get going on a cold morning.
Adjust the down pressure/force just enough to make the unit close properly. Do not over adjust the down pressure or you will find it won't stay closed. Sometimes the manufacturer doesn't make it too clear where this adjustment is, but you should be able to find it if you look around.
I have seen units that were installed for years all of a sudden need a little tweak of this adjustment.
Good luck
Mar 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not work in cold weather.
Leave car outside. Seriously, try a little more force to force adjustments.
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage overhead door will not go up in cold weather.
Pull the opener release rope and try yto open the door if it open hard the springs need adj. or door is binding in the track. if it opens easily then adj the lifting force setting on the opener
Dec 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster garage door opener that is erratic
Must be awfully cold . It is too cold in the early hours and don't work, it warms up in the afternoon hours abd it works. Solution move to florida
Dec 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
You can turn up the up and down force on the motor head to give the unit more power. During colder weather the unit needs more power. Afterward do a 2x4 safety reversal test. thanks, BB
Sep 14, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,403 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
