Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Power cycles Every so often the unit powers off and right back on. This seems to start after unit has been on for a few hours and does it 1-3 times a night. No other symptoms are noticable. Any ideas?
  • tmoore8878 Dec 06, 2007
    Would like a solution for the power cutting on and off on my Pioneer SD-533HD5 tv. Any ideas what is going on?
  • Anonymous Dec 18, 2007
    its been happening several times the tv will shot down and back on
    sometimes 3 to 4 times in a row
    whats my problem
    Genius:
  • 1,694 Answers
See solution for rheuer,same model. posted 10/5/07.
Posted on Oct 05, 2007
My Carrier 58STA quit. I killed the power and then started it after a minute or so. It started working fine after that. It worked fine for another 2 1/2 days and then it repeated the process.
this sounds to be a tricky kinda sensor fault , that's shutting it off , this is why it restarts when pwr is reset (resets safety shutdown) also this model is known to have control board faults due to control board being mounted right on blower housing (vibration) id have a tech ck it out they should be able to see if its a flame sense sensor or contrl board error
Dec 21, 2016 | Carrier Refrigerators
DLE9577SM Power issues. Control board?
  1. Power the dryer OFF and unplug it from the electrical outlet (You can also trip the circuit breaker if that's easier).
  2. Press and hold the START/PAUSE key for 5 seconds while the unit is without power.
  3. Turn the breaker back on, and power on the unit.
Mar 29, 2017 | LG Dryers
Why will it not turn on? the buttons seem dead
The unit is probably a few years old and the power supply has gone south..
Apr 30, 2014 | Audio Players & Recorders
Old Magellan GPS 300 is unable to find satellites after EZ start (relocated to another region and device was not operated for quite a while). Had similar problem in the past and recall there was a...
This is what I did to get mine going again. If your unit has lost all memory then you might find it tough to get it back online. It takes sometimes many many many hours
1. power off
2. press the power button;
3. immediately press and hold the right arrow button down until you see "delete memory" message
4. release the right arrow button;
5. select YES
6. press ENTER;
7. reinitialize the unit (EZSETUP)
8. Set the time to your local time (with no daylight savings)
9. Set the date to 7169 days from todays date. (if today's date is 1 Jan 2018 then set the date to 17 May 1998 (Yep its so old it has a Y2K bug)
It should take a few hours to pick up a pos
Dec 28, 2017 | GPS
Evaporator coils ice up after a few days and the refrigerator comparment only stops cooling. The unit is 2 years old. When removing the backing from the inside of the fridge and after thawing out the coil...
I have some information on your model and that would involve forced defrost by the service manual page 28 at bottom. How old is your Samsung? Forced Operation Function (Pull-down / Refrigerator Defrost / Refrigerator . Freezer-Defrost / Cancellation)
● This function enables a pull-down mode, a defrost mode for the refrigerator only, a defrost mode for the freezer and the
refrigerator at the same time, and a cancellation of this function.
● Press Power Freeze and Fridge Temp. buttons for 8 seconds simultaneously to get in the ready mode for a forced
operation.
● The display panel will return to normal after 20 seconds in the ready mode.
● At the ready mode, press any button(except Ice Type and Child Lock) once to start a pull-down operation, twice for a
defrost cycle for the refrigerator, three times for a defrost cycle for the freezer and the refrigerator, and finally four times
for cancellation of this function.
● Another way to cancel this function is to simply plug out and in the power cord.
1) Pull-down
1-1) At the ready mode, press any button once then the buzzer will beep (ON for 1/2 second and OFF for 1/2 second)
until this mode is cancelled.
1-2) At this pull-down mode, the compressor will start immediately (No 5 minute delay) and if the system is in the
defrost cycle, it will be cancelled right away.
note) If this pull-down mode begins right after the compressor was off, the compressor may not start to run due to an
overload condition.
1-3) At this mode, the compressor and freezer fan will operate continuously for 24 hours and the refrigerator fan will be
on and off according to the set temperature(34℉)
1-4) After 24 hour operation, the system will be cycled at -14℉ for the freezer and 34℉ for the refrigerator.
1-5) In order to cancel this mode at any time, select the next mode on the ready mode or power off the system.
2) Refrigerator Defrost / Refrigerator . Freezer-Defrost operation
2-1) At the pull-down mode, press any button again on the ready mode to begin the defrost cycle for the refrigerator.
2-2) The beep sound continues for 3 second at the beginning, then ON for 3/4 seconds and OFF for 1/4 second until
this mode cease.
2-3) After this operation, the system will come back to normal operation.
2-4) At this mode, press any button again on the ready mode to operate the defrost cycles for both compartments.
2-5) The beep sound continues for 3 seconds at that time, then ON for 1/4 second and OFF for 3/4 seconds until the
defrost operation cease.
3) Cancellation
3-1) At the R,F-Defrost mode, press ant button again on the ready mode to return to a normal operation.
3-2) Simply unplug the power cord, then plug it again to return to a normal operation.
Press both button for 8seconds at the same time Send maual in one moment, Thanks, Sea Breeze
Jan 20, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
How i can reset an a lowrance endura sierra?
Hello there:
here is what you can try to do is first unplug any power going to the unit and remove the battery these units have a internal reset device that will reset it'self after a given amount of time which is about 1 hour.
during this time press in on the power button for 2 minutes and if it has a reset button it press in on this for 2 min leave the battery and the power out of the unit for the rest of the remaining time i had mentioned.
now plug in the power cord back in it and start the unit now if it works ok simply turn off and replace the battery and you are now done ok
Hope this is very helpful for you
Best regards Michael
Dec 22, 2009 | Lowrance Endura Sierra Handheld GPS...
Mitsubishi HC1500 DLP Projector
This sounds like an overheat issue and requires return under warrantee.
Oct 06, 2007 | Mitsubishi ColorView XL30U Multimedia...
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Will not start - Seems to be stuck on Half Load & Economy Cycle
Try to unplug the power cable for few houres and then plug it again. It mighet reset the control unit. Good luck !
Jul 22, 2007 | Zanussi 24 in. DE6744S Free-standing...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
