Question about PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber
2g attache optima pro black/amber went to write protected...how do I fix it?
  • Anonymous Mar 05, 2009
    it cannot format
    President:
  • 281 Answers
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Posted on Feb 08, 2010
My sd card on my camera now says write protected...
Look for a small switch on the side. Switch away from the locked position.
May 20, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Access issue to my flash drive
The drive is probably password protected by Securlock software.
Hope it helps.
Aug 30, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I have a pny 2g flashdrive, how do I install it? It is pink and black.
This would be installed in a USB port depnding on your operating system it should reconise the drive right away. This drive will show up with a drive letter and the folder contents good luck and thanks for using fixya.com
Jun 26, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
I HAVE A PNY OPTIMA PRO ATTACHE 2 G AND IT WONT WORK IN MY COMPUT
then download the software, this device can run with his own program...
Jun 17, 2009 | PNY Technologies GeForce 6200 128MB AGP...
My flash drive says I am using data when I am not
i mean when i insert my flash disk in to the computer and then try to open it displays format disk
May 01, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
2g attache optima pro went to write protected...
You can see the following link
http://www.fixya.com/support/t275843-pny_optima_attache_4g
I'm not sure , if this would work for you, but you can definitely give it a shot . Fixing flash drive problems , the chances are 50-50.
Best of luck
Proton
Apr 05, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How do I change the stat of "writeable only" on my optima attahche 2g?
check another usb port I plugged my mouse in 1 port did not work plugged into another worked OK plugged thumb drive into port No 1 worked OK seems as if some usb port are funny
Jul 28, 2008 | PNY Technologies GeForce 6200 128MB AGP...
PNY Optima 2GB USB 2.0 Flash Drive - Dark Red/Amber Logo
336 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
