Question about Motorola Mobility RAZR V3m Cellular Phone
Beeps when going int or out of roam
Pretty much it
  • 31 Answers
There is an option in the Motorola v3m settings that will allow you to silence the audible alert when going in and out of your cell phone providers home network. End users use this to better manage their roaming minutes.
Here is a link to the operators manual to guide you in changing this setting.
Click Here
courtesy of Cell Phone Technicians
Posted on Dec 14, 2008
Please can you tell me how to turn off roaming? I'm using pay as you go.
To turn off roaming go to your settings app, wireless & networks, mobile networks, data roaming, and turn data roaming off. How to turn data roaming and data services on off on my Samsung Galaxy...
Dec 03, 2015 | Samsung S5600 Cell Phone
How do I op beeping of my Casablanca stealth fan Bulb is burnt and I removed he burnt bulb. would not top annoying beeping
Replace the bulb. If you are going crazy while getting a new bulb turn off the breaker for the room. A serious design flaw, I would complain to Casablanca if you have the time.
Oct 05, 2014 | Casablanca Fans Casablanca Contemporary...
Beeping at odd hours
It is probably either going in and out of roaming or loosing and regaing wifi anywhoooo to fix go to menu then settings and then sounds to turn off wifi alert by putting in airplane mode or also u can turn off roaming. in airplane mode u wont get any noise out of phone , just vibrate so u will have to turn it off to hear calls and alerts
Jul 09, 2012 | Cell Phones
8xx plantronics blue tooth will not stop beeping after a call. i powered off the blue tooth and beeps stops but returns after the first call
This issue may be caused by the network and not a defective headset. Changing your phone settings as listed below will in most cases stop the frequent ringing/beeping in your headset while in standby mode. You may want to check with your service provider before changing the settings listed below, as the following activity may cause additional charges on your phone bill. If you can, remove and re-install the phone battery. This should reboot the phone. Go into the MENU > SETTINGS > ROAM. Change roam setting to "ROAMING ONLY". Users will no longer get any Bluetooth headset rings/beeps unless the phone is actually ringing for an incoming call. This is a temporary work around since once the phone is turned off, the roaming setting above is reset. You will need to follow these steps each time you turn on your phone.
Good luck from Headsets Direct!
Apr 23, 2011 | Plantronics Voyager 835 Bluetooth Headset
Where can I get a description of what the lg icons are other than what is on the phone? Eg.What does ring and speaker mean? What does one beep and one beep &speaker mean? Roaming icon means what?...
Depends on what model it is BUT generally....
E911 is emergency calls only, meaning no service.
Ring and speaker is audible only
Beep and speaker is vibe and sound
roaming means you are on another carrier's network, other charges may apply depending on your plan.
1X is comparable to dial-up speed. If your in high speed area, you will see EV or 3G
Location is your GPS function on/off
Mar 28, 2011 | Cell Phones
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
International roaming
the lg enV is a cdma phone,
the world pretty much, uses GSM phones,
Aruba is GSM, therefore no service on lg enV.
International roaming of cdma phones, means-
part of the us,
part of canada,
part of the carribbean,
part of asia,
Jun 23, 2008 | Verizon Communications LG enV Cell Phone -...
Alarm beeping
Not sure, but the 1x active may have to do with some time of alert that you may have accidentally set in your calendar or alarm clock. Check your calendar and alarm for active alerts.
Dec 24, 2007 | Kyocera KX2 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
