Question about Sony XM-DS1300P5 Car Audio Amplifier
Sony XM-DS1300 amp
I have a sony amp. I was professionally installed. The amp works for a few minutes then it turns of. After a few minutes it starts working again. I ask the peolple that I had them installed the amp and they say it's the amp, because the wiring is good. I am thinking that the amp overheats and turns off, then once it cools down it starts to work again. What could be wrong with the amp? Is it something easy to fix or should I just buy a new amp? Thank you
    Novelist:
    Champion:
  • 218 Answers
If they have bridged the outputs of the amp, be sure that the "ohms" load is 8 ohms. This would then apply a 4 ohm load to each of the output channels. It sounds like they have bridged the output or else hooked up the speakers in a paralled configuration that is trying to kill your amp. If you are using dual voice coil speakers then you have to treat each of the voice coils as a seperate 4 ohm speaker and wire accordingly. You need to correct this NOW or else you will fry your amp. Good luck.
Posted on Mar 03, 2007
Amp kicks off after a few minutes of play. It will play again after a few minutes, but then kicks off again.
My best guess is that your over loading the amp. Check and see if the amp is hot when it cuts off. Most amps have a "safety" cutoff that will shut it off if it get to hot
Oct 26, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Jul 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
Sony xplod 1000 watt amp not working
you need a amp kit your battery or alltinator isn't powerful enough to handle the wattage you need a juice can it gives yur battery more power
Jun 30, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amplifier keeps running overcurrent
sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
No response from amp
it sounds like you have a bad ground make sure its on the froame or body and make sure any rust or paint is sanded or scraped off
Feb 09, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sep 23, 2007 | Sony XM-1002HX Car Audio Amplifier
Sony XM-DS1300P5 Car Audio Amplifier Logo
142 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
