Question about Toshiba 32AF43 32" TV
Remote sensor not working
Lately the remote sensor on my Toshiba 32AF43 has not been responding on an intermittent basis but the problem is increasing in frequency. I checked the remote (replaced the batteries) and it still works for my Toshiba DVD player. I even bought a new remote and the same problem persists. Now it's at the point where my TV basically doesn't respond to the remote and when it does it's only for a few seconds before it stops working again. Any help would be GREAT!
Thanks!
Kyle
  • 1 more comment
  • UberK Dec 10, 2008
    Thanks electech1. If that's the case is this something that can be done via a home repair service call? This TV is extremely heavy and wouldn't be easy getting out the door.
  • UberK Dec 26, 2008
    I checked into repairs for this problem and the cost isn't really worth it.
    Anyone know if you can buy an "external remote" device? Something you connect to your TV that replaces the existing remote system?
  • Pixel_Wolf Feb 10, 2009
    I have this tv, and I tried a universal remote, but since it used the sensor still it didn't work. I happen to have comcast on the way, and the cable box they have can at least change the channels. If it starts bugging me too much I might get the remote for the Xbox360 and see if that works, but most likely I'm going to get a new tv. My toshiba also has a horrible hum that is not fixable, and I got this tv used for $75 so it's not worth it. This tv has a nice picture, but it's way too heavy and annoying.
  • 905 Answers
Either the sensor on the tv is going or the eprom chip will need to be replaced along with a crystal that is on the chip
Posted on Dec 10, 2008
  • jason Dec 10, 2008
    you can try and call and see if they can work on it there at your home but most likely they will need to have it in the shop and the part most likely will have to be ordered , i would see if they can pick it up so you don't have to take it in , because it is a big tv they may come and pick it up , they will just charge about $50 more for the tech to come out to look at it then probably have to take it in to the shop , then they will bring it back after the repair
My comcast remote does not work on my tv
Setup codes to check with Toshiba TVs are: 10154, 10156, 11265, 10060, 10036, 10149, 10736, 10832, 11343, 11369, 11704, 11935.
These are codes with Comcast DTA remote control. If you want to know more codes and setup proceedings, check these sites.
Jan 16, 2013 | Toshiba 32AF43 32" TV
My toshiba 65in will not respond to my remote
The infrared sensor to your TV might be bad. It should be replaced. It is an easy to get part, and is cheap to buy from any electronic spare part shops. To access and replace it, you have to pull out the front panel PCB. In fact, you have to open the TV to replace it. The component will look somewhat like this.
9_25_2012_12_43_33_pm.jpg9_25_2012_12_43_54_pm.jpg9_25_2012_12_44_12_pm.jpg9_25_2012_12_44_46_pm.jpg
Sep 24, 2012 | Toshiba 32AF43 32" TV
Need to program the 32af43 to my dish remote need code
Here you can download entire pdf for the model number mentioned and in page number 15 and 16 you can find codes http://www.tacp.toshiba.com/tacpassets-images/models/36af43/docs/36af43_om_e.pdf
Feb 05, 2011 | Toshiba 32AF43 32" TV
Tv not responding to remote works sometimes
hello, usually if the remot control is ok, then the infrared receptor need to be replaced, he is placed near the stand by light.
in a rare case the problem is at the 5v voltage that goes to the receptor. more rare is the possibility
that something is wrong at the microprocessor circuit.
i hope it was helpful!! Let me know if you need further guidance
Dec 10, 2010 | Toshiba 32AF43 32" TV
Codes are not working
did you mean remote controll?
if you mean remote controll the common trouble of remote controlls is only three
1) the IR LED /infrared led
2) dirty contacts of keypad
3) leaky/open/shorted capacitor
Jan 05, 2008 | Toshiba 32AF43 32" TV
2002 Toshiba 32" TV
I have the same problem with a 2005 Toshiba. Got a new remote...nothing. Seems like a lot of people are having this issue, must be a defect in the TV. Has anyone contacted Toshiba?
Nov 22, 2007 | Toshiba 32AF43 32" TV
Toshiba 42H82 remote problem
Bad volume down tactil switch? Remove suspect switch and see----
May 29, 2007 | Toshiba 42H82 42" Rear Projection...
Remote help
What is the model# for your set? Find your TV set below: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Feb 27, 2007 | Toshiba CT-90157 Remote Control
Remote control code to program for directv receiver
What is the correct model@ for the set you own? Tv set that is... MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C
Dec 27, 2006 | Toshiba CT-90157 Remote Control
TV does not respond to Remote
possible defective rf receiver led defective in the tv.
Nov 21, 2006 | Toshiba 32AF43 32" TV
Toshiba 32AF43 32" TV Logo
695 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
