No sound I recently had the graphic card replaced in the tower. I cannot get sound back.
  • Greg Koelln May 11, 2010
    If your sound card was built into the previous graphic card, then you disabled the graphic card, that could explain it as well.
  • Frank
    Frank May 11, 2010
    you may accidentally pop loose the audio card. check the audio card, make sure it is seated
Reinstall sound card drivers download from maker of the card
Posted on Dec 11, 2008
AGP video card red lines
Hi, I apologize that you are having issue's with your computer. Lets see if we can get this issue resolved.
Be sure the tower is unplugged during cleaning.
  • First, if you haven't already done so be sure to use a can of compressed air to remove any dust from the graphics card as well as any other components inside the computer case.
  • Second make sure the graphics card is still properly seated into the AGP slot. Gently but firmly press down on the graphics card to ensure proper seating.
Once you have completed these two steps plug your tower back in and turn on the system. If you continue to see multicolored lines across the screen that means that the Graphics card will need to be replaced.
If you need any other help or need further clarification please don't hesitate to respond.
Dec 19, 2012 | ATI RADEON 7000 PCI Graphic Card
Windows won't launch,green check screen comes up,tried everything!!
I had something like this with a tower computer. I couldn't tell if it was the graphics card or the motherboard. I ended up dumping the computer. I saved the graphics card, but need to test it in another computer. I am guessing it is not loading because you may have switched it off at some point because of the checked green screen and may have damaged the operating system. Firstly, can you change the graphics card for another to see if this gets rid of the checked green screen. If this works, it won't adress it not loading, but could get rid of the checked green screen which is the first problem to deal with.
Dec 19, 2012 | Computers & Internet
Moniter reads no signal but tower light is on
Have you changed your resolution recently? Have you installed any programs recently? Have you made any hardware changes lately? Make sure the monitor is firmly connected to the tower and to the back of the monitor. Is the monitor plugged into the wall outlet? If you have two video ports on the back of the tower make sure you are plugged into the correct one, you may also try switching to the other port. Try another monitor if you are able to or try the monitor on another tower to see if you can isolate the problem to the monitor. Do you get anything appearing on the monitor when you first start the computer up? Have you been using a video card or onboard graphics?
Jan 04, 2011 | Acer Aspire X3400 (2702458) PC Desktop
When I start system I have this vertical stripes on display... and, when I try to install any driver my system freeze and restart
  • Second make sure the graphics card is still properly seated into the slot. Gently but firmly press down on the graphics card to ensure proper seating.
Nov 13, 2010 | MSI NX8800GTS-T2D512E Geforce 8800 GTS...
I put a CF photo card into the CF/MD slot right above the SM/XD card slot on my computer tower and the CF card kept going and is not inside the tower. How do I retrieve it?
It has to be in the card reader, it sound like it was inserted into the wrong slot and fell into the card reader. You may have to take apart the card reader to get your media back.
Oct 21, 2010 | ASUS Computers & Internet
I have a 2007 Mac Pro with a Radeon graphic card. It's red and plugs into the tower main frame. I recently purchased an LED cinema display and the mac sales rep said I needed to upgrade my graphics...
in this case it sounds like you will have to replace it, but why won't the GFX card you have cope? resolution or connectivity. The Radeon HD 2400 is quite a capable card.
Jan 07, 2010 | ATI RADEON HD 2400 PRO Graphic Card
What do i do if my computer monitor goes blank and turns on and the cords are all the way plugged in...is it the tower or monitors problem??
Hi There !!
Thank you for writing to Fixya.com
The monitor turn off & tun back on automatically, are the symptoms of Faulty Driver for graphic card, or Faulty Graphic Card & even could be the monitor it self. My suggestion would be to first, Uninstall & reinstall the drivers of the graphic card. If still problem persist you might need to replace the Graphic Card. But 80% of the times, drivers causes these kind of issues.
Steps how to change the Graphic Card:
  1. Static electricity can seriously damage the components inside a computer. To avoid this you must ensure you are grounded when operating inside your computer. One way to do this is to purchase an anti-static wrist strap which you should wear at all times. The wrist-strap plugs into an electrical socket which will automatically discharge the static electricity in your body.
  2. The graphics card or video card translates information into the graphics and text that appear on the monitor screen.
  3. Most motherboards now include a slot specifically designed for the graphics adapter called the AGP slot. This stands for Advanced Graphics Port.
  4. Modern graphics adapters usually incorporate some memory right on the card to improve their performance.
  5. To get into the tower you will have to remove the panel which is on the right hand side when viewing the tower from the back. Open this side of computer case by removing the screws at the back of the tower which are holding it in place. Then simply slide the panel off.
  6. Locate the old card on the motherboard and remove it by firmly lifting it out of the slot it occupies. Insert the new card, ensuring it is firmly pushed into the slot. Note: Some AGP ports have sliding locks that hold graphics cards in place. If your card is reluctant to come out or won't stay in, check if your port has these. If it does, use a screwdriver or your fingers to pull it to the right (open) or left (close). Make sure it clicks before removing or adding the card to minimize the risk of damaging the new card or your motherboard.
  7. Replace the tower's side panel, switch the computer on and install appropriate software that came with the new card.
Hope all these steps will help.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Home Edition
PROBLEM WITH MOTHERBORD AND TOWER SLOT ALINEMENT
well not all sound and graphics cards are for all motherbords i am sorry to say this but bay a new motherbord or better cards.hope i was usefull plzzz plzzzz plzzzz rate me.thx
Apr 08, 2009 | A-Top XBlade Mid-Tower Case
I've added a new graphics card and now get no sound.
I SUGGEST YOU READ A MAGAZINE CALLED CPU [COMPUTER POWER USERS]
FROM 11/2008 TO PRESENT ISSUES
ROD
Mar 12, 2009 | Computers & Internet
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
