My Revox B225 CD player is nearly dead. The only working function is the sliding drawer. The 5 fuses that I could find are fine. I have disconnected and reconnected every board, connector and the one IC that seemed plugged in, in case oxide had built up. I have the owner's manual but no service manual. I'd be happy to check voltages but don't know what they should be. Any thoughts?
  • musicanuck Dec 10, 2008
    I bought the B225 new about 25 years ago. Yes, it has a Standby mode, aka a "soft" power switch, that cannot be defeated. I always worried about that "feature" aging something prematurely. I'm fine with a soldering iron and will see if my local parts store has those electrolytics. There's plenty of empty space in the case if replacement capacitors won't fit on the board. Thanks for the lead.
  • djones53 Mar 23, 2009
    I have B225 which cannot access tracks if the left hand numeric keys are pressed - when pressing any of the keys the track does not show on the display.
    This is odd as if you press the program button the numeric keys allow tracks to be programmed - they can also be used to turn the deck on from standby.
    I would appreciate any advice - the uKs Revox agent says "retire" it!
    This would be a pity as it works well and sounds fine!
  • 71 Answers
Hi the problem is the capacitors in the power supply area it is hard to pin point whiich one it is if you are good with asoldering iron change the lot if the deck has a standby mode and left on in the standby mode this could be the cause if not just age and usage how old is the deck. regards kirk
Posted on Dec 10, 2008
  • kirk
    kirk Dec 10, 2008
    Hi againthey realy need to be replaced back in situ the tolerances are tight on this deck . a machine of this age can well do without a jump in voltage as the focus coils on laser could die also the static from you and the solder iron will kill the laser so earth your self and iron not to be a kill joy i have seen this so many times in the past ! dont expect to much more out of this think of the spindle moter as well how many times has that spun your discs basically your giving it back its full voltage spec ./ did you notice the display getting dim and weary if so the caps need changing there as well Good luck with your Repair regards kirk
Cd has fallen behind disk tray and drawer won't close
Remove the metal case/top from the whole unit. See screws at back and any at sides. You should then be able to see and remove the CD upwards, without removing the drawer.
Dec 14, 2013 | Yamaha Audio Players & Recorders
How to fix the CD player 6 CDs in my escalade ext 2005. 2 days ago it was working fine, and it stop working, the lights from the numbers of the cd box turn off and it doesn't work anymore, the radio and...
If the number lights are out and the CD player is also dead it sounds like you lost power to the player. Check all your fuses as the radio and CD player may have separate fuses. Also check any visible wires to see if there is a possible disconnect.
Oct 20, 2013 | Cars & Trucks
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
Hello, my Sharp Cd-sw200 no longer recognizes the cds that are in there and none of the 5 cd drawers will open. Everything else works fine. Unit is approx 3 years old and very gently used until 4 months...
Changers are the worse of the reliable units and Sharp is not among the best brands to get. The unit will need service by a Technician.
If none of the 5 drawers will not open how is it possible that the units works fine?
Dec 14, 2012 | Audio Players & Recorders
I think my Magnavox DVD/VCR is dead. How can I
remove the small screws from the sides, back and bottom. Take the top cover off by sliding to the back and tilting up slightly. You should then see the disc drawer with the disc in and some cogs to one side. You can manually wind the cogs with a small screw driver to open the drawer.
Feb 07, 2010 | Philips Magnavox DVD/VCR Dual Player
Cd stuck in drive.will not eject.
Hi ,
There might be a teeny hole beside or very near the cd tray (where the cd ejects from) You may have to open the little flap that hides the sliding drawer part.
Straighten out an ordinary paper clip, and push it firmly into the little hole.
The cd drawer should eject manually. You may have to pull it out carefully when it starts to eject.
Take out cd, and then close the drawer, and then try to eject it the normal way. Sometimes, all it needs it a little help.
I have a HP Pavilion a320n, and this happens to me about every 6 months or so.
Good luck,
Fred
Sep 16, 2009 | Tascam (CDRW900)
Revox B225 numeric key pad does not allow direcyt track access
That rep is crazy, don't retire it. The copper traces under the keypad are simply oxidized. This is common after many years. They can be cleaned and will work like new. You have to remove the faceplate, unscrew the keypad from the back of it and then you will see the traces. Simply take a pen or pencil eraser and rub it firmly across all of the copper traces. You might as well do both sides while you have it apart. You will notice them shine right up when using the eraser. Reassemble and it will work fine. Email me at cjkinpa@gmail.com if you have any other questions or need any further clarification on this.
Regards,
Chris
Mar 28, 2009 | Audio Players & Recorders
ADCOM GCD700 5 disc CD player
Are you sure the fuses located on a PCB below the opened drawer are all OK? Otherwise you likely have a mechanical issues and I suggest you contact an Authorized Adcom Service Center. For further information visit www.adcom.com and contact Adcom. Affiliated Electronics in Hillsborough, NJ, may be your best bet as they have salvage Adcom parts.
Nov 12, 2007 | Adcom GCD-700 5-Disc CD Changer
1,390 people viewed this question
 Grubhead
Grubhead
