Question about Aprilaire 550 Humidifier
Routing waterline to pad
I forgot how to route water line for aprilaire 550
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Tapping into the hot water line instead of the cold water line will aid in evaporation. Hot water line is recommended for evaporative humidifiers, including the Aprilaire 500 series.
Posted on Jan 06, 2013
  • wrenchmon574
    wrenchmon574 Jan 06, 2013
1/4" flexible copper pipe. Tap into your cold water line using the included saddle valve (pierces the pipe), attach the 1/4" flexible copper pipe to the saddle valve on the cold water pipe and the solenoid valve on humidifier unit using the included compression fittings. Tada!
Posted on Dec 29, 2008
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Dec 22, 2010 | Aprilaire 550 Humidifier
There is no water going into unit. The waterline looks good and is turned on. What do I do next?
Make sure you have all the elctrical wiring hooked up and that u are getting 24 volts to the solenoid valve.
Dec 20, 2010 | Aprilaire 550 Humidifier
My Aprilaire new water pad has a white substance on it. I mentioned this because twice the pad (tworeleased a sticky, mucous substance that plugged the drain line and caused flooding in my basement. The...
Hello,All the pads have a protectant(white) coating because the pad is aluminum and would rot out fairly quickly from getting wet.The slime is bacteria(fungus) not from the coating that forms from stagnant (sitting) water.Make sure the unit is draining out dry after each cycle.With the pad out pour vinegar OR bleach & water (10:1) to kill the mold in the drain pipe.Do not clean the pad at all ,it gets replaced.They sell an inexpensive wet floor alarm at the store that makes noise when wet.
Oct 12, 2010 | Aprilaire 550 Humidifier
I have an Aprilaire 550 hooked up to my furnace,
in order for the humidifier to come on with the heater there has to be a temperature sense curuit to turn it on/off at a certain temp, the humidity curcuit on the unit will turn it off at set %
Jan 31, 2010 | Aprilaire 550 Humidifier
How do I shut the water off to my Aprilaire 550
Hi follow the water line from the water valve back to the cold inlet pipe should be a tap on there
Jan 21, 2010 | Aprilaire 550 Humidifier
It's getting water from supply but not putting it thru to the pad.
the orifice after the solenoid is plugged. Shut water off remove line after the solenoid valve and clean orifice. This should do the trick.
Nov 03, 2009 | Aprilaire 550 Humidifier
It has been awhile since i removed my water pad and forgot how to route water line in pad
I've got a 560A, but if it's similar:  The pad sits in a plastic frame with the drain hole and "funnel" at the bottom.  At the top of the frame, there's a plastic piece that sits at the top of the pad; it snaps into the frame and the frame snaps into the humidifier housing.  The water tube from the solenoid slides into this plastic piece so that the water is directed to the top of the pad.
Dec 10, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 humidifier
Did you clean the orfice ? It is located on bottom of solenoid. It is plastic with a very small hole.The hole gets plugged and you can clean it or buy a nw one for 50 cents.
rdsvideo2@yahoo.com
Oct 18, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
220 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
