Wega Mininova EPU Espresso Machine
Problem for Wega Mininova EPU Espresso Machine
How do I know if the coffee beans are fresh?
By Lizzy - usenet poster
Best Solution
posted on Aug 08, 2005
Helpful)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
You will know espresso roast coffee beans are fresh if they have an oily surface.
Was this helpful?
Yes
No
Solution #2
posted on May 13, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Storing beans in the freezer or refrigerator will keep them fresh
Solution #3
posted on Jan 08, 2008
Not Rated)
JetJedi221
Rank: Master
Rating: 85%, 29 votes
Usually you can tell by smell. Fresh beans smell GREAT! Are the packaged with a one-way valve? If so, the package should be plump as fresh roasted beans give off carbon dioxide gas for some time.
Was this helpful?
Yes
No
Solution #4
posted on Jan 03, 2008
Not Rated)
Kimisuber
Rank: Apprentice
Rating: 0%, 0 votes
In fact the opposite is true: if the beans are oily it indicates the beans have been over roasted, and the oils have been forced out of the bean. If you don't want to take the time to roast your own beans, buy them direct from a roasting company. The best window to grind beans is from 12 hours from roast (to allow the gases to release), up to one week at the most.
Kim
Was this helpful?
Yes
No
Solution #5
posted on Dec 09, 2007
Not Rated)
same_cat
Rank: Guide
Rating: 84%, 9 votes
The strength of the aroma is greater when the coffee beans are fresh. Also the flavour is stronger and less bitter. However, although the ideal time to use your beans is in the first two weeks from roasting, you can however still use them 2 yrs later.
The only way to have really fresh coffee is to buy locally roasted coffee and in most cases you need to buy it direct from the roaster. Espresso drinkers will notice the difference when freshly roasted beans are used, however when milk based coffee drinks such as Cappuccinos or Lattes are consumed the subtle differences are often lost.
Always store your beans in a cool dark place but not in the fridge or freezer. Condensation can cause grinder problems. Using a dark oily roast can also cause grinder problems, especially if the bean tends to powder easily. Unless your grinder is easy to pull apart and clean I would suggest that you avoid beans that look too oily.
Was this helpful?
Yes
No
Popular Solutions for Wega Mininova EPU Espresso
Questions and Unsolved Problems for Wega Mininova EPU Espresso
Do you recommend Wega Mininova EPU Espresso Machine?
Answer
Answer
how do I hook up reservior? No longer have it plumbed into wall.
Answer
Hi, I have a older black and decker spacemaker coffee maker odc150 and I need parts black and decker... (More)
Answer
is there a video that shows how to install a black and decker spacemaker coffee pot
Answer
what I will install in www.mininova.org if other downloads are have a problem...
Answer
It's less than a year old and will turn off cup by cup of brew.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Wega Mininova EPU Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
