Question about Hotpoint NWXR473EV Dryer
Hotpoint Aquarius ctd00 tumble dryer "empty water" light stays on
We have been using the above dryer for about two years, it is set up so that the water produced flows along the pipe straight into the drain that the washer drains into, when the dryer operates we used to see a flow of water in the pipe flowing to the drain. We have never used the internal water tank to catch the water so it is therefore dry.
Recently the "empty water" light has come on and stayed on, the tank is still bone dry, but we do not seem to see a flow in the pipe to the drain.
The dryer seems to run okay and is hot - we have cleaned the condenser which you remove from the bottom left hand side of front.
Why is light on, where is the water going, we dare not use dryer in case water ends up all over the floor... any ideas ...... Thankyou.
  • keepers69 Dec 11, 2008
    I have just fixed it myself, I opened the grey plastic box at the back of the dryer that the tubes come out of, it just pops open with a screwdriver blade, the pipe which takes water to the drain had become detached behind this plastic cover (out of sight), the resulting flood had raised the polystyrene float which trips the warning light - I cleaned all the water out allowing the float to fall back to normal, at first the light stayed on, I then removed the switch (easy to do) and dried it out with a hairdryer before replacing it. Reconnected the hose and closed the box back up. Problem solved - light out and water now going to drain.
    I am rubbish at DIY so if I can do it anyone can.
barkencoa
  • 3463 Answers
SOURCE: Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Posted on Dec 26, 2008
  • 236 Answers
SOURCE: Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Posted on Feb 16, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
barkencoa
  • 3463 Answers
SOURCE: tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Posted on Feb 01, 2009
SOURCE: hotpoint CTD00 Tumble Drier: No water in draw, 3x as long to dry
sounds like pump has gone
Posted on Aug 31, 2009
I have a Hotpoint CTD00 Condensing tumble dryer. The pump which takes the condensate to the reservoir seems to be running continually and not relying on the float switch. I assume the pump should only...
No, the float switch activates when the storage tank is full. To confirm this lift the float and you will see the "Empty Water" light come on at the front of the machine.
Jan 15, 2011 | Hotpoint Dryers
Dryer revolves but no heat on any settings . hotpoint aquarius tumble dryer CTD00 7Kg.
fixed using posted advice on resetting thermostat.
Many thanks
Dec 10, 2009 | Hotpoint Dryers
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Oct 15, 2009 | Hotpoint Dryers
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Plz rate my solution.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Tumble Dryer-empty water light won't go off
remove panel on rhs looking from back and you will see a chamber with a microswitch on top. either micrswitch is stuck, pump faulty or a lint blockage
Jul 23, 2008 | Dryers
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
Mar 09, 2008 | Dryers
Dryers Logo
2,224 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
