Question about Janome D'cor Excel 5018
My bobbin cotton wraps around the bobbin holder and jams the machine
I have tried cleaning out the bobbin area and rethreading, but everytime the cotton continues to wrap around and around the bobbin holder in the machine, causing the machine to jam. How do I fix this?
  • Anonymous Mar 28, 2014
    Bobbin winder jammed and stuck on led screen Any suggestions?
I know this is probably not the answer but: are you sure the thread is coming off of the bobbin on the left side (bobbin in machine correctly), and when I first got my machine I tied to use the bobbins that I had on hand that fit my Singer machine. I had tons of problems with the "odd" bobbins that did not fit correctly into my machine. There is a VERY small size difference, but it does make a difference.
joanne
Posted on Jan 02, 2008
Bernette 75, thread wraps around bobbin housing, the bobbin fits totally inside the bobbin holder
Clean out the bobbin area thorougly. The bobbin must be the right size. If it is too tall it will cause the thread to wrap around the bobbin. Make sure you insert the bobbin and check to see if it is higher than the bobbin.
Aug 06, 2017 | Sewing Machines
I'm new at this and my thread is jammed. I've moved the hand wheel back and forth but the dog feed was jamming it as well as now that I've removed it the bobbing will not spin completely.
Most likely you have thread wrapped around and in the bobbin area of the machine that is not allowing the machine's handwheel or bobbin to turn completely. Open up the bottom of the machine and remove all the thread, etc. that does not belong.
Sep 01, 2016 | Sewing Machines
How do I get my machine to start sewing and stop beeping?
try rethreading the machine--use EVERY thread guide
make sure the needle is inserted up into the needle holder and turned the right direction
make sure the bobbin is inserted correctly into the bobbin case and turned the right direction
clean under the needle plate and in the bobbin area for loose thread or lint
make sure thread has not come off the thread take up lever
also the jam could have caused the machine to jump time and needs a timing or a adjustment
Jun 06, 2015 | Singer 7436 - INGENUITY
Bobbin Issues
On the bobbin holder, there is a tiny adjuster you should be able to undo or do up with fingernail or small screwdriver cotton should be firm when pulled by hand not to loose or not to tight.
Oct 19, 2017 | Sewing Machines
I have a singer 201 knee control and I love it until today.
try these suggestions
rethread the machine top and bobbin, using every thread guide
try a new needle--one for the fabric being sewed--make sure the needle is inserted correctly into the needle holder
make sure the thread does not come off the thread take up lever
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
Oct 29, 2013 | Singer Sewing Machines
Thread presser foot juki serger
try a new needle
make sure the bobbin is not warped or damaged
make sure the bobbin is inserted in to bobbin case correctly
if the problem still happens,, then it would be a good idea to have the machine checked for a timing problem
Sep 28, 2013 | Sewing Machines
I am using my mother's Singer Futura 1000 machine - probably around 20 years old but has been little used until recently. The bobbin thread has started wrapping itself around the bobbin multiple
try changing the needle
check to make sure the top thread has not come off the thread take
up lever
it could also be a problem with the timing and the machine
would have to be checked by a technican
Nov 26, 2012 | Sewing Machines
Brother 700e
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 16, 2012 | Brother SE-270D Computerized Sewing...
I can't get the bobbin thread to the to thread correctly in the machine in order to sew
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case, some
bobbins only go one way.
clean under the needle plate & in the bobbin area for lint & threads
May 01, 2012 | Elna Sewing Machines
Singer 3820 Bobbin Issues? I can't sew!
Unthread the machine completely, remove the bobbin.
Make sure that the bobbin case is securely in its place.
Turn the handwheel and ensure that the bobbin case is not jamming.
Turn the handwheel until the take-up lever is in the highest position.
Raise the presser foot and rethread the machine.
Chaeck the upper tension setting and set it around 5.
ALways make sure that you start sewing, stop sewing and thread the machine with the TAKE-UP LEVER IN THE HIGHEST POSITION.
Jul 11, 2009 | Singer 3820 Mechanical Sewing Machine
Sewing Machines Logo
290 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
