Question about Kenmore 96213 Electric Kitchen Range
Kenmore 96213 The oven door will not close tight
  • 72 Answers
A hinge bolt/screw may have loosened to allow the door to be out of alignment. Maybe try to flex the door side to side and look for movement to isolate which bolt/screws may be loose.
Posted on Mar 03, 2007
The oven door doesn't close tight
Hello, Anna -
The problem of your oven door not closing tightly could be caused by one of several problems:
* A problem with the door hinges
* Broken oven door springs
* A problem with the gasket inside the edge of the oven door
This article from the San Francisco Examiner newspaper describes the problems and how to fix them:
http://homeguides.sfgate.com/fix-oven-door-not-close-properly-28760.html
Best wishes.
Feb 07, 2018 | Ovens
Dont preheat
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 27, 2011 | Kenmore 96213 Electric Kitchen Range
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Kenmore Electric Range - Door handle Original bolts installed at the factory came loose and dislodged from the door handle.... no problems but this... i can not screw the handle back myself.. i tried......
We had the same problem. We had some tough epoxy that we squirted into the bolt holes, then screwed the bolts in. It took two of us, one to hold the door together and one to screw in the bolts. We didn't use the oven until the epoxy set, but now we no longer have a problem with the door falling apart every time we open the oven door!
Sep 28, 2009 | Kenmore 96213 Electric Kitchen Range
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Oven door just barely closes- light stays on
put a tea towel on both sides of the door [folded] down by the hinges then close door. gently push the door close try a few times with a little pressure.
Nov 12, 2007 | Kenmore 96422 / 96424 / 96429 Electric...
Oven door
dat, If your model starts with 790. there is a service flash regarding the hinges. Oven door not closing all the way. Affected model serial numbers VF-428xxxxx through VF-434xxxxx. There is a hinge kit for it, part number depends upon your full model number. You may want to call Sears and inquire about the service flash, you should be covered. Catriver..post back.
Mar 04, 2007 | Kenmore 96213 Electric Kitchen Range
Kenmore 96213 Electric Kitchen Range Logo
96 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
