Question about Canon PIXMA MP210 Photo All-In-One Printer
I have an MP210 Canon printer.  It is saying E 3.  The alarm light is on.  When I try to print, it says there's a paper jam; there isn't.  Help?
  • 9 more comments
  • baggy001 Dec 11, 2008
    I have the same sort of problem, when I turn it on it feeds the paper half way through then stops and feeds it back out again. It will not print and the red alarm light stays on. Suggestions anyone?
  • willy163 Dec 16, 2008
    Exactly the same problem. I ran out of paper - so what? - and since I can't print.
    Willi
  • scottyscott8 Dec 21, 2008
    From scottyscott888@yahoo.com
    I have the E 3 problem. However, there is no paper large or minuscule in sight. Let me know if someone else has a solution. Thanks
  • Anonymous Dec 23, 2008
    i have looked through this thing in very fine detail and found no paper jam! is there someway i can just bypass the error or something?
  • violet4_u Jan 01, 2009
    Status displays E and the alarm light is flashing...won't print or scan
  • itsmejennxxk Jan 08, 2009
    i the light flashes and the alarm light stays on and it says the paper is jammed. i dont understand how to make this probelm better
  • Anonymous Jan 09, 2009
    i am showing error E 5 any ideas
  • lrkolmel Jan 11, 2009
    I have the same problem. I get the E3 (paper jam) error and there is no paper, large or small, visible anywhere that I can see. Is there a way to reset/clear the code?
  • Staci Dunn-baumann
    Staci Dunn-baumann Jan 11, 2009
    my printer is showing 3E and is flashing alarm. There is not paper jammed inside. i removed it before it got stuck. Is there away to reset the printer? How can i make it start printing again?
  • Anonymous Jan 20, 2009
    i have a canon mp520 and it keeps saying paper jam when there is nop
  • Gabers Jan 21, 2009
    im having the same proble. i just bought inks for it. and when i insert the paper on the top. i try to print, and it keeps telling me that i have a paper jammed in there with the error sign. anyone know what i can do. thanks
Hi! have canon pixma mp210
i had the same problem E 3
and service button on
and B and C blinking(okay they are always blinking at my printer because i recharge it with syringe).
The cause of the problem was bad inserted paper -> paper jam
First i checked paper tray -> found a syringe fragment
opened the printer cover-> found a small peace of paper
but the printer was still blinking with E3 !
i began to disassemble the printer(be careful with a small secure part on the front side under control keys..i have broken this s it:) )
than i saw no other pieces of paper there.
i decrease the clips where the paper goes through(white plastic stuff) and put a sheet of paper there and started the printer again!
solved!
ps maybe it is better not to disassemble the printer and put in some way the paper between the rotating pulleys(because the printer had this paper jam and wants to have paper there to give it out)
copyleft balkonskijorg
Posted on Jan 12, 2009
I had this problem, i was convinced that there was no paper stuck in it, and in my frustration i ended up tilting it backwards and banging it on the table. i found a pen was lodged in the paper feeder. I was so relieved, until the error code was still flashing. then i stuck my hand down the paper feeder (take the paper out first) and found the smallest piece of paper stuck in it. try this.
i am so relieved.
Posted on Dec 13, 2008
What means error code E 5?My printer is showing these code and I can't do anything with-no scanning,no copying or printing.Please help me.
Posted on Dec 25, 2008
Ddssd
Posted on Jan 20, 2009
/*mp250 error code p03 alarm and on light flashing, color ink light on. trying to change cartridge but cartridge head will not go to the center so i can change it. help
manual replacing the print cartridges --> try rotating the left white gear back and forward releasing the mechanical lock of the print head it is a small plastic peace in the back of the of the head ...replace the cartridge as you need ...
about the error p03 it indicates a mechanical jam (head carriage - paper jem - paper pickup mechanizm - head cleaning mechanizm ) also clean carfully all sensors from inside ... it can give you a mechanical jam if blocked
Dec 09, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Paper dosnt feed in printer pixma mp210 photo. HELP
Either paper jammed, stuck by foreign object or DRIVE ASSY faulty.
May 25, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My Cannon Printer mp210 is flashing a 3-E. The light by alarm is on and it will not print or copy.
3 - E mean paper jamed. watch out inside properly some time paper cut stuck inside and its showing.
Jan 29, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Help
E3 says there is a paper jam somewhere, could be a small scrap, or even a bent or broken sensor lever. Just have to inspect inside carefully.
Dec 24, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have a acanon pixma mp210.. amber alarm light
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Paper Jam, yet no paper in printer. The last sheet came out whole.
I have a canon mp210 and it's saying paper jam..there is no jam. Paper is going towards the right when trying to feed but does not feed.
May 17, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
My canon printer pima mp210 the alarm button is on and cant get it off.... help
Check paper path (jam,or bit of paper), remove and reinstall the printer cartridges.
Also check to see if you have any print jobs "pending" and either run them or delete them and try again.
Remove the power cable from the printer for 5 minutes and connect it again.
Dec 02, 2008 | Office Equipment & Supplies
Canon PIXMA MP210 Photo All-In-One Printer Logo
1,670 people viewed this question
old marine
old marine
