Question about Audiovox AVP7380 Car Video Player
Player showing no disc
Tried several disc same problem, also tried to clean player but it also said no disc. can you please help?
0 characters
1 Points
Why player won't recognise disc
Several things can cause a disk not to read. You could have a bad disc, the wrong type of disc, the disc might not be finalized, the laser pickup could be dirty Try cleaning with a disk cleaner Other problems include bad or weak lasers the spindle motor could be bad ,the disk in detect switch could be dirty. The disk may not be loading into the proper position.These are the more common problems
Aug 07, 2014 | Nesa Vision NSD-790T Car DVD Player
Prob a dirty read eye or corroded laser tracking mechanism. requires removal, dis-assembly, and eye cleaned dry w/ Q-Tip or alcohol then dried w/ Q-Tip. Clean mech bars. same way. then 3-n-1 oil on q-tip lightly on bars
May 05, 2014 | Blaupunkt DVD-ME3 Mobile DVD w/ TV Tuner...
SHowing no disc even when their is a dvd in their.
trying getting a disc to clean the laser inside the unit, DVD cleaners can be found at your local Best Buy for about 10-20 dollars
May 03, 2011 | Audiovox AVD400 Car DVD Player
My XO Vision DVD player in my car headrests stopped reading discs. It says no disc even when one is in the unit. Tried to clean it with a cleaning disc and it didn't help.
This sounds like a laser problem. The laser is not recognizing that a disc is in the unit. The cleaner unfortunately is only for the lens
Nov 17, 2010 | XO Vision XOD1735 Car DVD Player
It says reading disk and that is as far as it will go.
the unit is trying to read the disc. when it cant do this as a security feature so the disc is not jammed in the unit it discharges it. the reason is a dirty laser or bad disc. as im sure you have tried several disc then i would move to the last stage or repair you need to get the lazer clean there are two ways to do this send it into the shop for a servcie pro to take the unit apart and clean the lazer. but in most cases its just a little dust on the laser lens that can be removed using a laser disc cleaner you can buy them at most electronics shops that sell electronic equipment such as tvs dvds etc. they range from $5 to $40. purchase one and run it through you dvd player several times and you should be right back on track..
best of luck to you.
Aug 02, 2010 | Delphi MV10018 Car DVD Player
Error message
hi here
you may have an unreadable disk or you just have to clean the lens of your player. always remember that the lens should always be clean to optimize its reading capablilities. just to be sure too, make sure that the disk you insert have no severe scratchings.
hope this helps.
Jan 31, 2008 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
"please check disc" ??? it's AVX 2404
This sounds like a dirty laser lens issue. try using a DVD lens cleaner disk if the disk does not work use a manual fiber optic cleaning kit with sponge swabs and fiber optic cleaning solution. These can be obtained from any electronic parts store (not radio shack).
Sep 19, 2007 | Eclipse AVN5495 Car DVD Player
Blaupunkt 7-inch Monitor reads no disc
Try several types of discs and see if any will load. This is usually caused by out of alignment laser assembly....Accordianman
Sep 29, 2006 | Blaupunkt Chicago IVDM-7002 Car DVD Player
No sound
Just in case: did you try another original disc? did you check the speakers wire? i am sure you did.. The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 18, 2005 | Jensen VM9510 Car DVD Player
Audiovox AVP7380 Car Video Player Logo
15 people viewed this question
Top Audiovox Car Video Players Experts
Michael Thomas
Michael Thomas
Jaime Hernandez
Are you an Audiovox Car Video Player Expert? Answer questions, earn points and help others
