Question about Sony Playstation 3 (PS3) Console
One of my sons managed to get 2 games into my ps3 consol
I have dismantled the consol and got the discs out the problem is the load and eject mecanism isnt working properly and the consol wont take discs how do i solve this problem can i do it myself or do i need to get it looked at by some one who has more knolage of the consol
So playstation 3 not good thing
Posted on Dec 11, 2008
When the ps3 turns on the blue light saying a disc is in it comes on and refuses to accept any discs at all and when i do manage to get the blue light off and put in a disc it has to be forced in and the...
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!.
Good luck.
Aug 20, 2010 | Sony Playstation 3 (PS3) Console
Disc stuck in console
okay turn off the console in the back
then 1. hold down the Power button AND the Eject button at the same time
2. reach around to the back of the console and turn the switich back on
3. wait a few second and the fans will kick on
4.and then the disk should be able to come out
hope that i could help!!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
Wheni put a disc in the ps3 it does not load up so i cant play on games my software version is 3.21
hi,
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
May 28, 2010 | Sony Playstation 3 (PS3) Console
My game wont eject
Okay, the same thing happened to me and I managed to get the disc out. First is the blue light on. If it isnt then you should hold the eject button and use another cd and push it into the disc drive and gently push your stuck disc around. When you hold the eject button your PS3 will make a loud clicking sound but dont worry. Just keep using the extra disc and push the stuck disc around and it should come out
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
Im unable to install disc in drive
I have seen several suggestions at the playstation*com PS3 forums in the past, such as:
| Zr0_C00L wrote:Try turning it off from the back,
| then hold the eject button while you flip the back
| power switch back on. Worked for my buddies
| when his died (good thing too, it was my game
| in there!)
| i too did the same thing and it worked for me.
This one with multiple discs jammed it sounds like it may apply to you:
"If anyone is having any problems, this is what worked for me. What is more amazing is that my son somehow managed to force 3 discs into that tiny slot...no idea how he pulled that one off.
So after two hours, a pair of tweezers, a fork, and a butterknife, I decided to try one last thing before giving up. I put the PS3 on its nose, disc tray down, held the eject button while it was on, and pushed a disc in and out of the drive. This caused whatever was in there to finally 'catch' as the drive had been trying to force everything out. After 2-3 minutes of play, a disc finally poked out. I pulled what i thought was one and two discs came out. I set it back down flat, tried to put a cheap DVD in (didn't want to test it with a $60 game) and it seemed something was still in there. I hit eject and out came the third disc. I put the DVD in reluctantly and the PS3 took it and loaded it right up. Unbelievable. After all this abuse, it's apparent these things are built like tanks."
You gotta love children.
Hope that helps.
Comments: Oh, one more thing I remembered to try before you ship it off to Sony or open it up. Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
My son's ps3 has his game stuck in it and we can't get it out- please Help if you can...
With the power switch on the back off press and hold the eject button and flip the power switch back on should eject the disc.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
My son has put two discs in ps3 and cant get either out now
I researched this problem since my twin 2 1/2 year old sons decided that my PS3 was hungry and needed a steady diet of 3 discs all at once. On a similar discussion board, someone discussed using butter knives to pinch the discs (one on top and one on bottom) and pull them out. This worked to perfection! Just be sure to pull the power cable from the back of your PS3 prior to sticking any objects (i.e. metal knives) into the front of it.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
