Ibm Weel Writer 5
I have an Ibm Wheel Writter % that will not type. I put in a ne ribbon, and the keys make nosie like its typing but will not typa a siongel letter or number. There is also some batteries in it that I have replaced. PLEASE HELP.
Also does anyone know of a good Repait place Located Clsoe to In Arkansas.
    President:
  • 3,594 Answers
Check to see if the ribbon is lifting up, if not there is a black gear on the right side of the printer wiggle it back and forth until it will move. If it is lifting put a multi part form a nd see if it prints on the copies if not the plastic on the print solinoid is probably broken they are available but a bit trigky to install.
DickyO
Posted on Dec 11, 2008
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
How do i get my Brother A X 250 Eletric Type writer to type the correct letters ?
"If your unit is not printing properly:
1.Ensure the ribbon cartridge has not run out of ribbon. If your ribbon appears silver or gray, install a new cartridge.
2.Ensure the black lever in the center of the carriage is pressed to therear towards the paper. If not, press it to the rear to lock the Daisy Wheel into place.
3.Reset the unit by holding down the [CODE] Key and pressing the [SHIFT]Key and the [WORD OUT] Key.
4.Release all three keys.
5.Try typing.
Feb 27, 2013 | Brother SX-4000 Typewriter
IBM Wheelwriter 5. It was typing light so I
The plastic print solenoid cap is probably broken. We sell them with instructions and shipping for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Feb 25, 2010 | IBM Wheelwriter 30 Typewriter
We have an old IBM Wheelwriter 6 Series II typewriter, but no manual. Need to know how do we program the typewriter to store information for forms that need to be typed that all have the same info?
First thing be sure the batteries are good. When it powers up it should beep once and the 1 light will come on. If that dosen't happen change the batt. and be sure the contacts aren't corroded.
There are 3 keys on the left side that say store, play and delete, hold the store while typing an address 01 - 99, release store, type info press store again. To print hold play and typa address. Delete works the same way.
DickyO
Dec 01, 2009 | IBM Office Equipment & Supplies
The wheel turns but it does not strike to make the type?
Remove the ribbon and turn the feed wheel to make sure the ribbon will feed by hand. Check that the ribbon is lifting each time you depress a key.You might also want to check that the platen (black roller) is seated down properly in it's latches.
Nov 11, 2009 | IBM Wheelwriter 30 Typewriter
New ribbon and can't get it to type
did you make sure that the end pieces are engaged into the brackets in the part facing you. Also if the correction tape is not loaded onto the ribbon prior to installing it, it will do that too.
Hope this helps, Denise
Aug 19, 2009 | IBM Office Equipment & Supplies
IBM personal wheel writer 2, wrong letter is typed
Try code "L" it will get you out or the language mode
DickyO
May 11, 2009 | IBM Office Equipment & Supplies
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 6
The plastic printer solenoid cap is probably broken, it is available but a little tricky to install.
DickyO
Jan 16, 2009 | IBM Wheelwriter 30 Typewriter
Ibm wheel writer 6
Hello, You have the lang. button on. Code L and that should turn it off. Cherie'
Jul 26, 2008 | IBM Wheelwriter 30 Typewriter
67 people viewed this question
k24674
