Question about Brother IntelliFAX 560 Plain Paper Fax
How can i change the ringer on my fax machine?
I want to know how to change my ring from one ring to four rings
  • 827 Answers
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Posted on Dec 21, 2008
How could the ring volume be adjusted (turned down or off) on a samsung inkjet tel./fax SF-340 series?
Hi!
To adjust the ringer volume, simply press the left/right arrow buttons, the SF340 must be in standby mode.
Every time you push one of those buttons, the ringer volume will be changed down or up. Volume 0 means no ring.
Please let me know if it helped.
Aug 10, 2011 | Samsung SF-340 Plain Paper Inkjet Fax
Would like to change the ringer setting so fax rings 4 or more times before picking up.
press
function
7
monitor key slowly 4 times
* star key
scroll down to NUMBER OF RINGS
set
change to 4
set
stop
stop
Mar 10, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
Telephone does not ring- call is displayed..call connects and can make a call
Setting Ring Volume...
You can adjust the ring volume when our fax machine is idle. You can set a ring volume or press until the ring is off.
Press 03f7f00.jpgto adjust the volume level. Each press of the key will sound the ringer so you will know the volume of the ringer you are selecting. When done, simply stop pushing the buttons and it will be set until you choose to adjust it again.
Nov 28, 2009 | Brother FAX 510 Thermal Printer
The Fax machine just gives me a problem on the screen (Ringer off), I don't know what is mean that, please Is it possible to recommend what I do.
It means that your fax will not ring when it receives the fax, but it will receive just fine.If you use this machine as fax only,don't worry about this message,but if you use it as a phone as well and you want it to ring,you will need to go to "menu" and turn the ringer "on"
Oct 04, 2009 | Canon LaserClass 2060P Plain Paper Fax
Need to silence ringer and have it pick up on first ring
menu, receive option, delay ring, options 0-4 choose 0! Done
Feb 17, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Increase rings on fax machine
Above the start button, there is a UP arrow button which is for increase of ringer volume, just press repeatedly to increase the volume. The down arrow is for lower down the ringer volume.
Jan 07, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Ring Cont on Canon LC 8500
lift up the 2 keyboard panels and press data registration and press set. scroll down using down arrow to RX settings and press set scroll down to turn ringer on and set the ring count to 3 and set and press stop a few times.
Feb 19, 2008 | Canon LaserClass LC 8500 Plain Paper Fax
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Ringing while fax comes through
there should be a setting in the menu options, under fax setup to reduce the ring volume as well as the amount of rings before the machine picks up.
Jun 21, 2007 | Brother FAX 930 All-In-One Thermal Printer
Brother IntelliFAX 560 Plain Paper Fax Logo
248 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
