Question about Zanussi F1045W Front Load Washer
Fx1365 door will not lock followed by four bleeps
Door will not lock, lock replaced no change, if lock simulated shut by shorting out grey leads machine will start to fill.
  • chris_kevinb Dec 14, 2008
    Have checked brushes thay are worn about 20mm left but appear to be OK
  • chris_kevinb Dec 15, 2008
    Thanks for the help I will let you know the outcome when I get time to check it out once again thanks
  • Zanussi Master
  • 3,463 Answers
From what you say,I would be looking for a fault on the programmer, sounds like you are not getting a neutral feed.
By shorting out the lock you have created a circuit through live and common, causing the m/c to operate.
Check carbons in motor.
Posted on Dec 10, 2008
  • Barry Coates
    Barry Coates Dec 14, 2008
    Carbs obviously not problem, suggest it could be control problem.
Door keeps flashing
Possible your door has not been shut properly. Open the door and shut again. Or try some WD40 spray on the door of the machine, not on the body, or it could short circuit something. If all this does not work just change the lock mechanism, quoting your model and brand; you could find spares on the net.
Mar 31, 2013 | Hotpoint First Edition WMA22 Front Load...
My bosch classixx6 1200 express keeps flashing the key/lock symbol and bleeps so I cant start a programme
The door is not locked properly or the door lock switch is not functioning. In the second case the door lock functioning can be checked by bypassing the door switch (for testing only). After bypassing the switch the program can start. If it succeeds replace the door lock switch.
Aug 07, 2011 | Washing Machines
Wmf720 hotpoint washing machine,after loading the washer and shutting the door,i switch on the machine it doesn't start the programme.....what is happening is the word door is flashing on the screen and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest, sorry ;-0(
Good luck,
John C
Mar 30, 2011 | Hotpoint Washing Machines
When pressing the start button on my washing machine it makes 2 clicking sounds at the door and then bleeps and the program goes to end. Could this be the door lock?
It possibly could be. If you push in on the door when it's closed and push start, does the door lock and the machine start. If it does than it is probably the door needs to be adjusted.
Mar 01, 2011 | Washing Machines
44082 is the model #
he code "dr" means the control doesn't see the door switch being closed.This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced.
Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem.
The switch can be obtained from the following link: Sears PartsDirect . Remember to unplug the washer first before attempting to change the switch.
The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
I hope this information helps you resolve this problem but submit another question with any additional details for further assistance.
Helpful attachments:
The code "dr" means the control doesn't see the door switch being closed. This can mean the door catch is broken or the door is bent and not shutting all the way or clothes are preventing the door from shutting all the way but most likely it means the door lock assembly needs to be replaced. Check the door strike is not broken and make sure the door is shutting evenly. If the door is shut fully and the "dr" error keeps occurring then replacing the lock assembly 131763245 will most likely fix this problem. The switch can be obtained from the following link: [Sears PartsDirect |www.searspartsdirect.com] . Remember to unplug the washer first before attempting to change the switch. The image below contains the instructions to access and change the latch. Changing the latch is easy the tough part is putting the spring back on. Sometimes it helps to have two extra hands when trying to reinstall the wire/spring.
Apr 15, 2010 | Kenmore 43042 Front Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
LOADED MY BOSCH CLASSIXX 6 1400 EXPRESS CLOSED THE DOOR THEN TRIED TO PUT IT ON A PROGRAMME AND IT CAME UP -0- AND IT WOULD NOT START NO TIMES WAS COMING UP WHEN I TURNED THE DIAL ONTO A PROGRAMME.PRESSED...
this sounds like a door lock issue if the machine does not detect the door has closed properly you will get the same symptoms, try slamming the door shut (not too hard) if machine starts but then does the same thing next time you use it will need new lock it will have gone out of calibration.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Maytag MAH5500B
Buzzing sound is probably door trying to lock. May just need a new door lock.
Feb 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door Lock LED flashing
Hello, This depends on how old your machine is mine is now 7 years old so I do not want to invest in long term soltions. So I repaired my own, I bought a new interlock and replaced the old one that did not work. So I shorted out the three links that go to the interlock, the machine now shows the lock is always on and you can open the door during the wash cycle so BEWARE. Also if you have never wired a plug or fixed basic electrics DO NOT DO THIS. 1. Turn off power and unplug. (Very Important) 2. Remove lid you will need torx drivers. 3. Unscrew door interlock from the front of the machine. 4. Lift out interlock. Try replacing the interlock with spare first (about £15). 5. If new interlock does not work do the following. 6. Put Interlock back on without wires attched to it. 7. From car spares shop buy spade conectors and create a three way shorting link (insulate well). 8. Put shorting link into each of the wires that go to interlock. Safely tie up wire to a loom (do not let dangle) 9. Shut the door remove hands and try starting the machine. 10. If that works put the machine back together. And warn people that the DOOR CAN BE OPENED DURING WASH CYCLE and STARTED WITH DOOR OPEN. So check when the machine has stopped properly.
Oct 20, 2006 | Hotpoint WMA58 Front Load Washer
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
Zanussi F1045W Front Load Washer Logo
90 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
Richard Roth
Richard Roth
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
