Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool washing machine gearbox won't turn agitator,motor just makes a humming sound,the coupling sleeves are metal to prevent breakage-how do i fix it?
  • 71 Answers
Here is a good site for that.
http://repair2000.com/coupling.html
Posted on Dec 12, 2008
I recently replaced the broken drive coupling on my whirlpool washer but it still won't agitate or spin. Could there be an electrical issue with the washer lid switch?
If it sound like the motor is running and you get no agitate or spin but it drains, and the couple is new, then you have a bad transmission. If the washer makes a hum like the motor is jamb, then look inside the pump. If the washer make's no sound at al after fill then the lid switch in normally the problem, but secondary problems could be faulty timer or motor.
Mar 26, 2015 | Whirlpool Washing Machines
My whirlpool thin twin washer wont agitate it just makes loud sound but will fill up with water
Your washer most likely has a broken drive coupling. If broken the washer will fill with water and drain, but the motor spins without driving the transmission (no agitate or spin). The part is common to all whirlpool washers made in the last 20 years and is readily available at all major appliance part stores. It is possible to change this part yourself but much less hassle to get it changed by a pro
1485646-1-s-jpg.jpgSee Part # 13
Search all parts
in this section
USE WPL 285753 (Direct Drive Motor Coupling)Part Number: PS1485646
This coupling kit is used between the motor and the transmission on direct drive washers with no belt. This is the newer version and is made with new metal sleeves for added strength.
CAD$12.81
Oct 24, 2012 | Whirlpool LTE6234D Top Load Stacked...
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
I have a Kenmore top loading large capacity washer model 1028882791. It began washing as usual then began to making a loud humming sound. The agitation stopped. It only makes a loud humming sound. I...
The humming sound is coming from the drive motor running but unable to drive the agitator nor the basket to spin. The drive motor is definitely running as the drain function works because of the fact that drain pump is directly coupled with the rear spline of the motor. The drain pump works in either direction as long as the motor runs. The problem is obviously a broken motor coupler which transfers the mechanical energy of the motor to the transmission. The solution then is to replace the broken coupler. Click on the link below for the detailed step-by-step procedure in replacing the motor coupler.
Replacing Motor Coupler on Kenmore and Whirlpool Top-Load Washing Machines
Jan 13, 2011 | Kenmore Washing Machines
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
I have a whirlpool lxr6232eq0 that is making humming noise
perhaps the clutch is caught up, have you tried lubricating it some? it may help..
Apr 29, 2009 | Whirlpool Washing Machines
Possible transmisson
motr coupling easy to turn??? did you look at closle ( sometimes appears intact, but the center of teh shaft is stripped allowing the motor to "slip" through giving what could amount to a stripped gear sound. the newest motor couplin (285753a) has a meatal sleeve to prevent such a thing from happening
Mar 20, 2009 | Whirlpool Washing Machines
Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Machine hums
There is a coupling between the motor and the gearbox that has probably broken. It is two pieces of rubber that fit together like a puzzle. It acts like a weak link to protect the far more expensive components. Check under the machine for some fine black shavings in a little pile at about the middle of the machine.
Feb 19, 2007 | Whirlpool GSW9800PW Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
1,044 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
