Question about E-Machines eMachines Monitor E15T4
Emcahine Monitor sound is low
I have an emachine monitor (21.5") I bought recently from Tiger Direct. It has build in speakers at the bottom but I cannot get much sound out of them. I have all the volume settings I know how to control at the max. How or where can I increase the volume further.
  • WayneLeeH Dec 11, 2008
    Yes, I connected the sound cable from the sound card of the tower. I get sound , it is just very low volume. There is no vol control on the monitor speaker rail. There is only a mute button
  • Frank
    Frank May 11, 2010
    did you connect the on screen speaker cable to the tower??
    there should be a volume control on the right of the speaker rail.
    Genius:
  • 1,605 Answers
Check the speak rail, the emachine speakers need a amplifier, there should have a power supply plug, that you need to plug it in.
if not, call up the place you brought the machine and ask them, where is the amplifier plug.
Posted on Dec 12, 2008
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Monitor works perfectly, but after a recent crash of my comp. Ive lost all sound ..The comp doesnt seem to recognize the build in speakers..
The computer does not have to recognize the powered speakers that are built-in the monitor, the computer feeds the analog audio signal the powered speakers inside the montior, there is no driver needed either, but you do need the PC sound card driver for you to get sound through any powered speakers (either the desk top powered speakers or the one inside the montior).
Since your computer had crashed, the driver for the sound card may be have to be reloaded.
You can verify if the monitor speakers are working or not by feeding it with an MP3 player or sound output from CD player.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 14, 2011 | BenQ FP72E 17" LCD Monitor
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
Resolution issue with Emachines E211H flat panel monitor
Try to restart ur PC then it will auto detect ur monitor via DVI input. Actually, no driver needed for monitor in now day, they all come with plug and play.
Mar 22, 2010 | E-Machines eMachines Monitor E15T4
Weak sound from speakers. Advueu A170E1-02 17 inch flat screen
I'd bet you need the monitor driver(s) installed. If you can't locate to install them, your only option for sound is external speakers plugged into the speaker port on the back of your pc (usually green color).
Sep 18, 2009 | Advueu Technology ADV1711DB Monitor
White screen, power switch not functioning.
Unplug it, reset it. Did it come with install disk? Try running that with your old monitor. The system may not recognize it as plug and play or the monitor may be defective. Call Tiger Direct or whoever you bought it from for support.
Jun 24, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Monitor turns pink quite frequently
i think problem is the vga cable of monitor try to remove the cable of your monitor attache to pc or try to reconnect the vga cable
May 21, 2009 | eMachines E17T4W 17" Monitor
I recently bought a prowiew monitor from a friend, and would like to know how to get sound from the built in speakers.
Proview monitors with built in speakers have a jack on the bottom for an 1/8 inch stereo audio cable connection to the sound card.
EXAMPLE:
http://www.proview.net/Support/Download_UM.aspx?sn=459
Sep 07, 2008 | Computers & Internet
Sound
If your monitor have inbuilt speaker, then you need not to plug it, because the monitor cable will work for that. I have ViewSonic 19" with inbuilt speaker and its working without any extra cable or connection.
Thanks
Iqbal
Mar 23, 2008 | Acer AL1916W 19" LCD Monitor
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
597 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
