Question about Maytag MGR4451ADS Stainless Steel Gas Kitchen Range
Sealed Burner Two sealed burners on one side of Maytag Gas Range (model # CHG9800BAB) were not sparking. Replaced both burners with new ones. New burners do not spark when turned on. Sometimes they give off a couple of weak sparks. When burners are turned on, using a match, and knob is turned to the ?Start? position, the burners spark normally. They seem to spark while they are still hot. After they cool off, they do not spark.
    President:
  • 878 Answers
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Posted on Mar 03, 2007
HOW TO CONVERT FROM NATURAL GAS T PROPANE
Their are 2 types of ranges. Ones with sealed burners and ones that do not have sealed burners. The sealed burner ranges must have a kit to replace the orifices. The none seal burner models are simply called crank down and flip models. That means you flip the screw on top of the regulator to where it reads LP. and then you tighten down the spuds on the top burners and the oven valve and then you adjust the air shutters.
Note: Some stoves with sealed burners cannot be converted to LP. The model number you posted is not a correct model number.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 19, 2010 | Kenmore 72002 / 72004 Kitchen Range
The front burner won't light.
I assume the other burners are lighting and the spark ignitor is working - if so try cleaning in and around the burner. a spill could have caused this problem. this should be a sealed burner model - if so make sure the burner top cap is on and seated correctly and or not gunked up with a spill. also check to make sure
May 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kitchenaid superba gas range slide in, model #KGST307HBS9. The nob of one burner, only, the left rear, will initiate the electronic spark that will light burners. When that nob is turned to...
Pull out the bottom drawer and you will find the spark module. I strongly suspect it is weak. Here is a video that shows operation:
This one shows the module on the backside but I looke dup yours and it is below in the backside of the bottom drawer. Ok here is what i think The igniters could be dirty and I have a video showing how to check that plus another video to show how to remove those pesky switches on the top burners and spark module operation.
TOP BURNER SPARK IGNITION
SEALED BURNER SCREWUP
Jan 02, 2010 | Kitchen Ranges
Burner igniter won't click or work
This is an easy problem to fix. If your repair man is correct and it is the spark module and not a wire harness problem you can pick up a spark module as sears for about $37 and it only takes a couple of minutes to install. Just pull off the back panel and replace the module. This is a repair that anyone can do. I would recommend unplugging the unit before replacing.
Jun 20, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Igniter Problem on One Burner
Peace,
ngafm here at your service,
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that one burner.
Or you just have a bead igniter.
If you have sealed burners and the cap and burner where the gas comes out, is removable by hand without tools!
You may want to check the gas holes in the removable burner is clear and or clean them out if they are clogged.
How old is the range?
I hope that these measures will help you remedy the problem simply and easily!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Sep 04, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
My maytag gas range has sealed burners. They need to be adjusted because they dont ignite properly and they blow out when you turn it on high
Peace,
How old is the range ?
You may have some food that spilled into the burner and it could be causing the gas not to fully flow out of that burner so
it will come out with force.
Bless you,
ngafm
Thank You
Jun 08, 2008 | Maytag MGR5751AD Gas Kitchen Range
May tag gas range 30 inch
Peace,
i think that gurgling noise is the gas trying to get out and is neing blocked by a over boil or food spill on the sealed burner with the holes clogged!
Bless you,
ngafm
Thank You
Feb 04, 2008 | Maytag MGR5751AD Gas Kitchen Range
Range mgr 5745 sealed burner
Yes the burner does twist off. You must turn it counter clockwise about 1/4 of a turn. These can be stuburn at times so what you might want to do is strike it sharply down with the heal of your hand first then give it a twist. this seems to help.
Nov 08, 2007 | Maytag MGR5751AD Gas Kitchen Range
Maytag MGR4451ADS Stainless Steel Gas Kitchen Range Logo
310 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
