Question about Dell OptiPlex GX270 PC Desktop
When the power on switch is pressed, computer powers up momentarily, then shuts down. Both power supply fans run for only an instant.
    Problem Solver:
  • 17 Answers
I've had the same problem with another computer..
The simple solution, instead of buying and installing a new internal fan is to place the computer on its side and put a small electric clip-on fan directly over the vent. Turn on the clip-on fan and then start the computer; the clip-on fan should generate more than enough cooling so that the computer doesn't overhead.
Two notes:
The clip-on fans usually have the clip on the back of the fan so you can clip it to a bed headboard or to a small pole or shelf; the fan is about six inches across, and they sell at Target, Wal-Mart,, etc., for anywhere from $15 to $25, but you can usually buy them at Big Lots or similar stores for about $5 and you can sometimes find them at the Dollar stores.
You can use a larger fan, but a larger fan will generate too much wind. You want to use an electric clip-on fan and not a battery operated fan because a battery operated fan won't generate enough wind/cooling.
And, if the problem ends up being more than simply a cooling problem, you can at least use the clip-on fan later.
Let me know if this works.
Posted on Dec 10, 2008
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
When I turn on my computer it runs for a couple of seconds and then stops.
Unplug everything inside the computer, except the motherboard and the front panel power on switch. Power up the computer. If the PS fan continues to run, (power supply doesn't shut down)and the CPU fan runs, then power off the unit and reinstall each device, one at a time, turn the power supply on after each device is installed (and off, before installing the next device).
You can not easily start the power supply if it is not connected to the cpu motherboard.
If the power supply shuts down with only the motherboard attached, then you will need either another power supply, to test the MB, or another MB to test the power supply.
Feb 02, 2011 | Acer DPS-420GB (dps420gb) Power Supply
The computer suddenly shut off and will not turn back on. I assume the power supply is shot. The computer was kept on constantly, and was seldom shut down. I have opened up the case and it is extremely...
there are two posibilities...
1 ur power supply is out, to check if ur power supply is OK, check if fan on power supply is running when u switch on the PC, if it works then that's OK
2 - ur motherboard is out, if this is the case ur CPU fan will not work but ur power supply fan will work
to check both u may have to open the PC
Dec 14, 2009 | Sony VAIO PCV-RX470DS PC Desktop
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Mother board 845 LDA as i switch on LED Blinks & Processor Fan Momentarily Starts then it gets off
I have built quite a few PCs and I have often found the same problem when trying to boot for the first time. An old trick that might help is to repeatedly energize then drain the PC electricity.
Do this by plugging in the PC momentarily then unplugging it then immediately pressing the power button on the PC while there is no power hooked up. Do this several times over and over again in quick succession. Finally turning on the PC with the power connected. If the power supply on the PC has a switch on it you may use that instead of actually plugging and unplugging.
Also you might try pressing and holding down the "ins" or "insert" key while powering on the PC.
Hope this helps.
Apr 25, 2009 | Intel Motherboard
When is the Hipro HP-A2007AE power supply cooling fan to be on?
The fan should run constantly. It needs to be replaced. Otherwise the power supply will shut down when it gets hot. It can usually be replaced, but if the supply is cheap, just go out and get a new one.
Mar 17, 2009 | Computers & Internet
Asus a8v-vm se fans always run
Hi jderek4, try this. locate the toggle switch on the back of the power supply. Just find it do not flip it.
Plug the PSU's power cord into the PC. Just as you got a good connection & the PC begains to power up move the toggle switch to it's other position. The PC should power off that very second.
If the PC does not shut off than the PSU is bad. If it did shut down wait a few seconds. Press the cases power on button. The PC should start to boot up. Let it finish loading. Click the start button & choose to shut down windows. The PC should shut off.
Yes? If not than your back to (bad power supply). Swap it out.
Mar 29, 2008 | ASUS A8V-VM Motherboard
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Presario S4020wm desktop
You need a new power switch. I am currently working on a S4020WM with the same problem. I cut one wire to the power switch, then used a paper clip to make a jumper to start the machine. It has run fine since then. The only trouble I am having is finding a replacement switch.
Sep 04, 2007 | Compaq (480082-001)...
Dell OptiPlex GX270 PC Desktop Logo
130 people viewed this question
Alun Cox
