Sounds like the flame sensor is failing you. The sensor is located on the last burner looks like a thick piece of wire. Take some steel wool and gently clean the carbon off the surface of sensor. Should only take 5 or 6 strokes. Now if that does it let me know. ken
I cleaned the sensor, when inspecting I saw what looked to be an ignitor in the back it looks like it came off of a white holder in between the two burners. I'm guessing that it needs to be attached and since it is broken needs to be replaced. If this is true is this something that can be purchased easily?
OK I replaced the ignitor, and also replaced the fuse, and it is still acting as it did before everything is starting except the ignitor is not getting hot I'm stumped, do you think its time to call the service man or is this something I can tackle myself?
