Question about Durabrand DWT2405 24" TV
TV plays some channels in spanish
I have a friend that has a Durabrand TV and it plays certain stations in spanish. She doe's have cable but their is no cable box. A transformer blew out and it has been doing that since. What can possibly make the tv play certain stations in spanish instead of english like it should
    Novelist:
    Champion:
  • 236 Answers
The tv may a SAP circuit fault (Second Audio Program). This circuit can mess up and cause some channels which are carrying SAP to put out the wrong language. I've seen this happen a few times. AN IC may have gotten zapped when the transformer blew. Possibly the microprocessor IC. Stargazer
Posted on Mar 03, 2007
How do I connect to my Vizio TV?
Yes. On TV remote. Select input highlight s video tune TV to correct channel
Jul 26, 2015 | Durabrand DVD-1002 DVD Player
Two stations are coming in spanish but only during football games.
tray to re search your tv set but look the tv standard for audio
Nov 25, 2013 | Sanyo Televison & Video
I have a Durabrand TV and all I want to do is connect my DVD player to it. However, I can't find a channel on the TV that I can play it on. Do I need some kind of code?
DVD players are usually connected with TVs by using AV cable. Your tV will have AV input sockets at its rear side. After the interconnections have been done, select the input to TV to AV. The picture of the AV cable you need is attached.
Jun 08, 2012 | Durabrand Televison & Video
Is the durabrand dwt2704a a D-TV and is so why am i only getting channels 18, 23, and 50?
Nope, your TV is not directly compatible with the new broadcast format. You are, however, able to use a set top converter box, and feed the signal through the cable connection or through the RCA connection as well.
The stations that you are able to see (18,23, 50) are low power stations that are not required to change over to the new broadcast format.
Oct 12, 2010 | Durabrand DWT2704 TV
I have no remote. how do you get a dvd player to work on the tv.
May have to be set to a certain input or even just channel 3
Most inputs can be accessed through a tv menue
Apr 12, 2010 | Durabrand BH1304D 13" TV
Durabrand DCF2003
try opening it up and clean the remote with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.then assemble.be sure your batteries are ok.
May 28, 2009 | Durabrand DWT1905 TV
Trying to help this older lady with a emerson tv/vcr combo. She has no manual with set. Setting up to record same station everyday at same time. VCR will record but when playing back she only gets sound no...
The TV should be on channel 2, 3, or 4 to work correctly. There might be a small switch on the back of the VCR that lets you select the channel that it wil play back on.
Also, look on the remote control for the VCR and see if there is a button labeled TV/Video, and press that while something is playing. This switches back and forth between the TV signal and the VCR signal and it could solve your problem.
Jan 08, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Connecting TV to combo DVD and VCR
When you say "can't get the TV to play through the VCR", do you mean that you can't get the cable-stations to play through the VCR to the TV? I'll assume that's what you're trying to accomplish.
The most common way to connect a VCR to a TV is through a coaxial cable, from the port on the rear of the VCR labeled "Out to TV." There should be another coaxial port labeled "Cable/Ant In." This is where I picture your cable programming is currently connected.
Instead, it sounds like you connected the VCR to a modulator (probably thru RCA composite cables, which have yellow / red / white plugs). Then the modulator connects to the TV thru a coaxial cable. This will successfully play the VCR to whatever specific channel (perhaps 2, 3 or4), but the modulator doesn't know of any other signals to send to your TV.
2 possible solutions:
1) If the modulator has a coaxial port labeled "Cable/Ant In" or something indicating "In" at a threaded coaxial port, connect your cable-programming to this instead of the to the VCR.
Depending on what type of modulator it is, when you want to switch from watching the VCR to watching cable-programming, you might have to push a button on the modulator to make the swtich, or you might not. Your modulator might put the VCR on channel 3, and allow the higher cable channels to filter though to their respective stations. Most cable providers will leave channels 2, 3 and 4 blank for this purpose. Try it and see.
2) Axe the modulator. Take it out of the system entirely. Connect your cable programming to the VCR "Cable/Ant In" and use another coaxial cable to go from the VCR's "Out to TV" port to the TV. When you want to switch from watching the VCR to watching cable, press a button on your VCR or the VCR's remote. Usually this button is labled, "TV/VCR."
If this does not help, write back and explain in more detail how your system is currently connected.
--axoplasm
Nov 02, 2008 | Televison & Video
Durabrand DWT2405 24" TV Logo
180 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
