Question about Sony PSone Console
PSOne CD Drive Problem
My PSOne's CD drive doesn't seem to initialize -- I power it on, no beep, and the CD drive doesn't even start to spin, laser doesn't move at all. What is recommended?
  • Justin Goldberg May 06, 2009
    So how do we fix this?
I had the same problem.The problem is that the cd drive is stuck.
Posted on Jan 25, 2009
My playstation one worked fine when I used it from the last 10 years that I didn't use it and I started having problems with the System because when I put a game on it. It turns on fine but then it ta
seems to be the newer version of the the psONE so i will say to get a CD cleaner first to try to fix the problem. if that fails, consider replacing the laser unit. ti make sure the laser is even working, stick a pen or something into the lid switch and look to see if you cna see a red laser beaming out. dont look straight into it though.(obviously) if you see nothing, or the motor doesnt spin, you have a problem with the whole CD/Motor unit.
Oct 11, 2012 | Video Game Consoles & Games
My 2005 Harley sportster XL1200 starter whines but does not turn over the bike. The battery is charged but it doesn't seem as if the starter is engaging sounds more like it's spinning fast. Can you...
check that the pinion drive pivot pin on the solenoid is in place as it appears to be moving the solenoid to make contact but not moving the pinion out into the ring gear
if it is the type where the pinion is thrown out into the ring gear by the initial spin of the armature then use powered graphite in the shaft to help it slide freely.
Nov 02, 2011 | 2005 Harley Davidson XL 1200 R Sporster...
I put CD into cd tray, the tray and CD go into the player, it says loading, but nothing happens and it continues to say loading. I cannot even eject the CD, I have to power it off and back on to get the...
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.....
Sep 14, 2011 | Philips MX6050D System
Hi, I have a colleagues laptop here which seems to power up for a few seconds but then doesn't go any further. There is definitely power getting through the motherboard, and the HDD spins up, but...
I believe that is a No Post issue.
Its not the hard drive because you said " and the HDD spins up, but it seems as though it doesn't reach POST" or else you 'll be getting errors associated with the hard drive
There are some laptops even though it has a RAM NO POST issue will not beep
" no display and no beeping at all "
For us to determine if this a Motherboard Issue we have to disconnect all parts that can be disconnected. Disconnect the hard drive, Memory (RAM), battery, if you have a Modem daugther card, Express card, PCMCIA Card.
Try Turning the computer on using the Power Adapter hooked up on the computer. If you are still getting issues Definetly that is a Motherboard have gone bad but we really need to check up other parts that are disconnected
If Motherboard is good you will be getting video but it will stop on the POST screen and you might be hearing beep sounds as well. That means that the Motherboard is fine. Put the parts that are disconnected and clean the metal contacts as well one at a time and try to isolate at what part that is bad
Jul 05, 2011 | HP Compaq nx6325 Notebook
Will not play or burn cd or dvd
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
hope this may help;
DON'T FORGET TO RATE;
Regards,
VOTIT
Mar 23, 2009 | Pioneer (DVR-106D) DVD±RW Burner
CD player
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Sony MHC-RG20 CD Shelf System
Ps2 slim line
if the laser is moved to the middle of the area and when you first turn it on it doesn't go back to starting possession's then some thing is wrong with the motor drive more than not it's likely you have a crack in the board.
Jan 03, 2008 | Sony PlayStation 2 Slimline Console
PC boots up, but no display and hard drive does not seem to spin
Actually you do want to hear one beep.
This is POST. Power On Self Test.
No display is a video problem. Swap the card for a known good video card. You should be able to get into the BIOS with that. Presario’s are quit.
While in the BIOS see if the HDD is shown. It doesn’t hurt to check the connection inside. Please keep yourself grounded when inside the PC. For the Compaq Presario S4020WM site go here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=326832&lang=en&
Dec 04, 2007 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
Sony PSone Console Logo
237 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
