Question about Sony KP-51WS500 51" Rear Projection Television
2002 sony projection screen tv kp-51ws500
I brought my tv to a repair shop 45 days ago my tv wouldn,t turn on the power light would flash 6 times. now it does it again the same problem the repair shop told me it would be another 400.00 dollars in labor after i just spent 600.00 dollars 45 days ago so it now turns on for 3 sec. and shuts off then blinks 7 times. can someone please tell me what the problem can be i can't afford to put any more money into this television. thank you
    Problem Solver:
  • 18 Answers
Attack SONY - this is a design problem and sony should compensate U or repair this set. NEVER BUY SONY AGAIN
Posted on Mar 11, 2007
  • 103 Answers
The set has a bad tube Don't spend any more money on it
Posted on Mar 06, 2007
Powers on then right back of light flashes 8 times
Looks like a problem on the convergence board which requires repairing/replacing..
Oct 30, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
TV turns on then off
the green crt is most likely shorted. thats fairly common with that chassis.
May 04, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
i have a sony wide screen projection tv KP-51WS500 Red stand by light on flashs no picture
Mar 10, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 Blinks/Flashes 6 Times
nspect the bottom of these boards for cold solder joints with a magnifier & resolder suspect pins, also check the capacitors on the board, if they are little silver smd type look for yellowish liquid to be present around one or several of them, you need to replace, either of the above could be your solution.
Jul 20, 2007 | Sony KP-51WS500 51" Rear Projection...
Turns Off By Itself
it helps , if you can tell me how many times the red led blinks , but for that model usually the hi voltage splitter cause that problem,
Jun 09, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
118 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
