FixYa.com
Tags:
ASUS Processor Board
Asus P3V 4X DIP Switch problem (by 3 users)
posted by angelfire74 on Mar 03, 2007
I'm trying to set up a PIII 450/512/100/2.0V on the asus board. It's set to jumper free and all the switches are off but when I start up the computer it says press f1 to continue, then goes to "we apologize..." and you have your choice to start in safe mode, safe mode with networking, last known good configuration and load windows normally. When I choose load windows normally, it just reboots and does the same thing over.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by wilbr, posted on Nov 22, 2007
I am trying to install a Tualatin 1.2Ghz cpu (1.45v) on an Asus P3V4x motherboard using a Asus S370-133 rev 1.01 adapter.
I set the mobo in jumper free mode (JEN pins 2-3 "'ON'') and DIP switches U12 are all ''OFF''.
DIP switches on S370 are set to DEFAULT (1-2,1-2,1-2,1-2,2-3) and the cpu type(J6) is set to 1-2(coppermine).
I use BIOS version 1006.0004.
When I power my PC there is no BOOT, I only get a black screen(in DOS).
Is there a solution to this problem?
Thanks in advance.
Bernie
Comment by Guest, posted on Nov 19, 2007
can i use a intel(r)celeron 1.10ghz in this board pga 370 a how to set the voltage output thanks and more power
Best Solution
posted on Mar 03, 2007
Helpful (85)
Bogdan
Rank:Guru Guru
Rating: 89%, 378 votes
Hello.
This is more a software related issue. If it were from the processor itself you couldn't power on or received weird error during Power ON Self Check. If the processor was overcloaked windows will indead try to start but fail. Therefore, if you know you haven't overcloaked the processor you should try to reinstall a clean copy of windows by booting the computer with the windows installation CD. Hope this helps, good luck and always remember to rate the solutions received from this site :)
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Processors problems?
Processors
i d number
miss placed product i d number... Answer This...
Processors
email
I'm really disappointed in the... Answer This...
Processors
Processor speed
I have a emachine desk top and... Answer This...
Processors
Window Vista business - window...
i had Laptop Toshiba model... Answer This...
Processors
driver
mass storage controller Answer This...
Repair Service
Find Processor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
