Question about Citizen Eco-Drive Calibre 8700 Wrist Watch
Day and date don't change at midnight. But change at 9 o'clock am
My Citizen Eco-Drive 8700 perpetual has a small problem which can't figure out. The day and date don't change at midnight. But it will change at 9 o'clock in the morning. I did the reset twice and the result was the same. I set the date and day in the 'CAL' mode and then set it back to 'TME'
Who can help me??!!!
    Problem Solver:
  • 5 Answers
Before using this watch, be sure to check that the functions of the watch all operate
correctly.
What is a Reference or 0-Position?
The term "reference or 0-position" refers to those hand and date positions used as a
datum point for the correct operation of the watch.
[Checking the Reference or 0-Position]
1. With the crown pulled out one step to position 1, rotate the crown to align the mode
hand with chronograph [CHR] mode as indicated on the mode subdial.
2. Pull the crown out two steps to position 2 and confirm the reference or 0-positions.
The 24-hour hand, hour hand, minute hand, second hand, function hand, and date will
rapidly advance and then stop at their current reference or 0-positions.
3. Confirm that they are showing the correct reference or 0-positions.
Correct reference or 0-positions for each hand and the date
Correct reference or 0-positions are given below.
24-hour hand : 0:00
Hour hand, minute hand : 0:00
Second hand : 00 seconds
Function hand : 0 position (12:00 position)
Date : 1st
If any of the hands or the date shows a
reference or 0-position other than given
above, perform the procedure given in
"Correcting the Reference or 0-Position"
[Correcting the Reference or 0-Position]
<Correcting Reference or 0-Positions of the Function Hand and Date>
1. In chronograph [CHR] mode, pull the crown out two steps to position 2 and hold down
button (A) for 2 or more seconds to correct the reference or 0-positions of the function
hand and date.
2. Rotate the crown to the left or right to adjust the date.
(1) The function hand moves 1 step at a time for each click of the crown.
(2) Quickly Rotate the crown 2 or more clicks consecutively to move the function hand 4
revolutions and advance the date by 1 day. Rotate the crown to the left or right by 1
click to stop rapid advance.
•The correct reference or 0-position for the function hand is the 12:00 position
immediately after it changes to "1", while that for the date is the position immediately
after it changes to "1".
After setting the date to "1", Rotate the crown 1 click to adjust so that the function hand
points to the 12:00 position.
The correction mode changes each time the upper right button (A) is pressed while the
crown is pulled out two steps to position 2 in chronograph [CHR] mode.
<Correcting the Reference or 0-Positions of the 24-hour Hand, Hour Hand
and Minute Hand>
1. Press and release the upper right button button (A) to correct the reference or 0-positions of the
24-hour hand, hour hand and minute hand.
2. Rotate the crown one click at a time to adjust the 24-hour hand, hour hand and minute hand.
(1) Rotate the crown to the right 1 click to move the hour hand and minute hand clockwise.
(2) Rotate the crown to the left (counterclockwise) 1 click to move the hour hand and minute hand
counterclockwise.
•Quickly rotate the crown 2 or more clicks consecutively to advance the hands rapidly. Rotate the
crown to the left or right by 1 click to stop rapid advance.
<Correcting the Reference or 0-Position of the Second Hand>
1. Press and release the upper right button (A) to correct the reference or 0-position of the second
hand.
(1) Rotate the crown to the right 1 'click' to move the second hand 1 step at a time.
(2) Quickly rotate the crown 2 or more 'clicks' consecutively to advance the second hand rapidly.
Rotate the crown 1 'click' at a time to adjust so the second hand stops just before the 12:00
position.
•Return the crown to its normal position to complete the correction.
Note:
The second hand cannot be moved in the reverse direction.
Posted on Aug 02, 2013
How do I set the date on a calibre 8700 perpetual calender wr 100?
<P>Thanks for contacting FixYa.</P><P>You can contact Citizen here:</P><P>CITIZEN TECH SUPPORT <A href="http://www.citizenwatch.com/COA/English/settings.asp">http://www.citizenwatch.com/COA/English/settings.asp</A><BR></P><P>Thanks and best regards. Jewel</P>
Aug 31, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
Date in window doesn't change properly and day pointer doesn't point to correct day at times
RECOMENDATION:
Seek professional help.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
May 12, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
I bought this watch citizen BL5334-04E year ago,
Mechanically operated date changes occur at 12 O'clock. If your watch thinks it is midnight when it is noon then it will change date.
The solution is to wind your watch on 12 hours.
Apr 17, 2010 | Citizen Eco Drive Perpetual Calendar...
I have an Citizen Eco Drive Perpetual wrist watch / calibre 8700. I can't adjust to the right date/month. please help.
This will likely require you taking the back off, removing the battery, reinserting, and then shorting the battery and AC. You will also need to look up the manuel online from Citizen's website, or go to a jeweler to have them reset your perpetual calender.
Oct 16, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Day and date not synchronized with actual day and date
The watch does not have a "perpetual" clock so it does not know what month it is in. It will treat every month as a 31 day month, so you will have to re-set the date anytime a month is not 31 days.
If you appreciate me answering this for you then please rank this solution as "fixya" or at least "helpful" as what I have said will solve your problem. :-)
Jan 09, 2009 | Citizen 8700 BL8000-54L Wrist Watch
Watch
You should be able to pull the crown out 1/2 way and turn the crown clock-wise and you should hear a click and the calender should move one day. Don't change when the hands when the time is between 10 and 2 , just manually move the hands past that time , and re-set afterwards. If that dosn't work let me know ,.There are other types of those watches , but the way I told you is the most common.
Jul 07, 2008 | Citizen Eco Drive Perpetual Calendar Watch...
Need assistence in setting the date and day on my citizen 8700 eco drive
There is an ID number I need to help you further it is the Movement Caliber number probably on the back. Once I have that I can help you further.
Regards,
Worldvet
May 30, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Citizen Eco-Drive Calibre 8700 Wrist Watch Logo
1,083 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
