Question about Canon PIXMA MP160 All-In-One InkJet Printer
Wont print it is making a loud noise and there is a long clear strip that came out and i cant figure out how to put it back in i think it goes where the ink goes back and forth and it keeps on showing an E on the window where the numbers are....
  • chris Sep 20, 2012
    did you resolve this issue? I have exactly the same problem
Did you resolve this issue? I have exactly the same problem
Posted on Sep 20, 2012
freetek
  • 5568 Answers
SOURCE: mp160
Before you try this, put a couple of drops of resin-free oil such as 3 In One (sewing machine oil) or a tiny bit of penetrating lube on the shiny rod on which the carriage rides.
The original lube may have either dried out or has turned into a paste-lube gunk that is making the carriage hard to move.
If the 'rubber band' has teeth on the inside, it is the printhead drive belt and it may be stripped.
If the printhead centers for cartridge changes when opening a cover, let it center, pull the power cord out of the wall and carefully attempt to move the carriage by hand.
If you hear a similar noise, then the belt is stripped and will have to be replaced.
I'm not familiar with your model so can't advise if this is a do-it-yourself job or not.
Posted on Jul 14, 2008
jmassengill
  • 345 Answers
SOURCE: Horrible grinding noise
The problem sounds like a broken or stripped gear in the printer. If the unit is under warranty I would contact the authorized repair station for that printer in your local area.
Posted on Nov 10, 2008
  • 153 Answers
SOURCE: Canon Mp480 wont print!
you have a purge unit problem, if you have done a few cleans then throw machine away cost more to fix it. but a new printer
Canon tech
Posted on Apr 01, 2009
  • 73 Answers
SOURCE: cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
2) Remove the empty FINE Cartridge.
a) Push down the FINE Cartridge.
b) Remove the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Posted on Nov 26, 2009
pineworks
  • 4041 Answers
SOURCE: i turn on my printer and the ink cartridge makes a
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
It says clear the carrier jam and press arrow to continue. There is nothing to clear. It makes a loud noise when you press start? It it worth taking it somewhere to be fixed?
No, might as well buy a new one rather than have it fixed. You can try cleaning the encoder strip. It's a clear plastic strip that runs though the printer cartridges. I clean mine with a light alcohol on an old T-shirt (or other soft cloth). clean one side then move it to the other and clean that side. But be easy, the encoder strip is a pain to put back on if you pull it off (and it does come off easy).
Dec 03, 2010 | Dell 924 All-in-One InkJet Printer
I hear a loud ratteling noise coming from where
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
Apr 16, 2010 | 1996 Jeep Grand Cherokee
My daughter pulled this long plastic strip out HP PSC 1210
Sounds like it is the guide strip that pushes/pulls the print carriage back and forth?
Sorry but it is not a repair easily carried out at home, if at all. If in one piece and not broken it might be re-introduced but the bottom line is you will most likely have to purchase new? Sorry. it might cost just as much if taken to a repairs?
Nov 15, 2009 | HP PSC 1210 All-In-One InkJet Printer
When trying to print, it says I have a carrier Jam.
HI!! in your case my diagnose is that maybe the the incoder strip was defective and need to replace it.
Jul 12, 2009 | Lexmark P4350 All-In-One InkJet Printer
HP OfficeJet 6110 (4 years old) makes short grinding noises during printing. Occasionally the printer stops and asks to have the door opened and the jam cleared. The problem is gradually getting worse....
Try first to clean the encoder strip. It's the clear strip behind the printhead. Either use a Q-tip dampened slightly, or small towel. Don't apply too much pressure though, it can come off and they are hard to put back.
Jul 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Print unable 50
The carrier that goes back & forth has a timing strip ( a plastic strp about 1/4" wide and goes the legth of the machine) If you open the top cover. put your hand in the hole fill twards the front of the machine and the top cover. now the carrier has a U shaped sensore that this strip goes through. 9 times out of 10 the stip has gottin bummped out of position. now you need to put that strip back in the sensore. hard to do with covers on. if look close at the top cover not that hard to take off.
good luck
Jan 07, 2009 | Brother Fax-1360 Plain Paper Inkjet Fax
When you start printing it starts making loud banging noises
It's called an ENCODER STRIP you will have to revmove the covers to reinstall.
Jan 02, 2009 | Dell 924 All-in-One InkJet Printer
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Lexmark P4350 print catridge does not move.
Sounds like the photo sensor for the "transducer" for the cartridge assy is not working (or there is a power supply related problem....)
Look for loose connections of any cable from the small blocks on either side thin strip that goes through (behind) the the cartridge assy.It has thousands of verticle lines on it.....
They could also be dirty (Incorrect speed sensing).
(Try to clean if printer is dirty...Be careful not to blow i the cartridge assy area as the ink may fly everywhere)
DO not touch the thin strip with verticle lines .Very Delicate...
Feb 09, 2008 | Office Equipment & Supplies
Printer-squeel
The squeeling I think has to do with a small build up of ink on the carriage.
What I do is I open up the printer top so you can see the carriage as if you were putting in a printhead and then you unplug the power to the printer when teh carriage is in the unlocked position. Now you can freely move the carriage back and forth. If you notice there is a clearish long strip going from one side of the printer to the other that is placed flat ontop of the entire metal inside casing of the printer. Clean that entire strip with a cloth or something. Now take a piece of paper and fold it a few times so that it ends up looking like a ruler you can say. Put the paper flat on that clear strip and then take the carriage and move it over the paper. Basically your cleaning the underpart of the carriage that touches that clear strip that is attached to the metal body of the printer. Move it back and forth and you will see ink being put onto the paper thus cleaning it.
Just close the case up, plug in your printer and the squeaking should be solved till next time. As for that light problem, don't know what those lights mean. If there is a problem with teh printhead or ink though it will always tell you on the digital read out, or at least should.
Jan 19, 2008 | Computers & Internet
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
