Question about Fujitsu Plasmavision PDS-5001 50 in. Television
Fujitsu 50"plasma TV
The sound keeps going off, for about 2 seconds at the time. It seems to do it more often on channel 7
Not yet solved the problem, I have replaced the Arial and cable but still loosing sound occasionally, not as often as before. Maybe it is the LG HDMI receiver.
Posted on Mar 17, 2007
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 50HP95 Plasma TV Manual
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
My Plasma TV is having problems on Channel 31 (not sure of the frequency assigned)
Do you have an old VCR? because they used to work around this channel. If not forget what I said. If so, try changing the output, or if you don't use it, put it somewhere else.
Jul 17, 2014 | Sanyo 50" Plasma Hdtv Dp50740a W/ Free...
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
I have a Fijitsu 50 inch plasma tv. I installed it on the wall, hooked up a speaker. I get sound on one cable channel with no video or I switch to another channel and get video without audio. I cannot...
OK ~ try this... Connect a makeshift antenna to your Antenna proper connection/connector.
Almost anything somewhat large, flat and is metal should work OK... Even a length of old lamp cord may work too! Hopefully you are in range of at least ONE standard HDTV DIGITAL broadcast transmitter(s) "over the air".
IF your audio is now OK suspect that CABLE BOX!
And how about your DVD player? Is your audio and video good using it?
Anthony
Jan 29, 2018 | Fujitsu 50 in. Plasma TV
Have 50 inch samsung plasma tv.have sound but no picture.
If the sound is still going and you can change the channels then the problem is most certainly the ysus or zsus board.
May 20, 2010 | Televison & Video
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung 50" plasma won't turn on
Same problem.damn inferior product.I knew I shouldve stick with sony.Ive had mine for 7 months and according to the guy I bought it from hes had it almost a year.No power
May 20, 2008 | Samsung PS42P2S 42 in. Plasma Television
Fujitsu Plasmavision PDS-5001 50 in. Television Logo
149 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
