Microphones
Problem for Microphones
Generic problem for all Microphones
Poor - choppy sound when I run my imac on ...
By nashgrandpa on Dec 10, 2008
I use windows xp for paltalk application and when I either use the internal Imac mike or a generic plug in microphone - the words are garbled and volume output is very low.
Comments:
Dec 22, 2008
- audio out is great - if I use the internal mic in other programs such as yahoo chat  or messenger (on the mac) - it is fine too.  Sees as though the problem is with paltalk but I really dont believe that.
When I open my mixer - the microphone IN vertical slide is in ghost - all of the other slides are in green.  So is this something to do with bootcamp / or mac dont like the soundboard mic in and will not see or accept it.
Dec 22, 2008
- I use windows xp for paltalk application and when I either use the internal Imac mike or a generic plug in microphone - the words are garbled and volume output is very low.
Comment posted on Dec 22, 2008
Solution #1
posted on Dec 10, 2008
Somewhat Helpful)
masterexpert
Rank: Wiz
Rating: 84%, 76 votes
check out the volume settings first and increase it as much you require.and also check out the wiring connections and instead of that program try listening any songs or audio from that same speaker to confirm the exact fault.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
bunnydawg
Rank: Guru
Rating: 85%, 2082 votes
Memory issues... you need to add more memory to your system and also get rid of any spyware as it will slow down your system... i recommend spybot s&d for that... as well defragging your system will often help as well
Was this helpful?
Yes
No
Solution #3
Not Rated)
leecom72
Rank: Guru
Rating: 89%, 2574 votes
hi there
you will have to set the mic up properly with the system, go to the control panel and select "sounds" to set up the microphone's different audio levels
kind regards and Merry Christmas
Was this helpful?
Yes
No
Solution #4
Not Rated)
Maanita
Rank: Wiz
Rating: 83%, 448 votes
This seem that you need to uninstall and reinstall a fresh driver copy.
Was this helpful?
Yes
No
Solution #5
Not Rated)
ginko
Rank: Guru
Rating: 89%, 5212 votes
Check if this also happens with an external driver.
Comments:
Dec 10, 2008
- Check if this also happens with an external microphone. If you don't get the bad sound using an external mic, then the connection to the mic is shorted, and the mac must be taken apart to fix the problem.
If the problem persist using an external mic, that means that the audio controller is bad, or the software recording software has a problem. Solution is trying to reinstall Mac OS, if that does not work, your MAc audio chipset is faulty.
In this case you have two choices, either you replace MAC motherboard, or you buy an external audio adapter, like this one:Amazon.com: External 5.1 USB 3D Audio
Was this helpful?
Yes
No
Solution #6
Not Rated)
Maanita
Rank: Wiz
This is a driver related issue get the driver reinstalled.
Comments:
Dec 10, 2008
- At first uninstall the paltalk software and then reinstall it back
Was this helpful?
Yes
No
Popular Solutions for Microphones
Questions and Unsolved Problems for Microphones
Answer
I Have a Sony ECM MS957 microphone and think the signal is a bit low. Is it any way to ajust this?
Answer
I have two ev co9 mics, neither of them seem to work, where should I start???
Answer
I have a Liberty MPB 4500, and every time i increase the sound it get disconnected Why?
Answer
Hi, I have an MK5 Magic Mike and when I plug it into the T.V, the screen is just green and it is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microphone Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
