Question about Sony DRU-710A DVD±RW Dual Layer Burner
DVD Drive will not open, has DVD stuck in it
The DVD drive will not open. It tries to, but its jammed. It won't open at all. You can hear it try to open, and then close itself back up again. Then it will load the dvd I have in the drive. Any suggestions on how to get this thing open? I'm about to take a screwdriver to it!!
  • danzarwel Dec 10, 2008
    Thanks for the help. I hear it trying to open, but it still won't. When i stick the paper clip in I feel something trying to push it back out. Is that normal? Again thanks a ton for the suggestion!
  • danzarwel Dec 11, 2008
    I changed it to Fixya! Awesome work Dan! I love the name too!
    Problem Solver:
You are the MAN! It worked like a charm! Thanks a bunch! How the heck can i change that rating?!?! This is a Fixya for sure!
Posted on Dec 11, 2008
    Sergeant:
  • 236 Answers
There should be a small hole by the tray. insert a paper clip here and the drive will open manually
Posted on Dec 10, 2008
  • Dan
    Dan Dec 10, 2008
    Yes, that is normal. The resistance is you pushing against the gears. Be firm but not crazy and the drawer will start to open. Once it is open a little, you can pull it put with your hand.
  • Dan
    Dan Dec 11, 2008
    I'm glad to help - us Dan's have to stick together. :-)
    Thanks for the rating!
Stuck CD/DVD drive. Won't open
There is a hole on the front of the drive. Push an unbent paper clip into ththe hole and it should release the drawer.
Jul 04, 2012 | Acer Aspire X1300 (PV.SCC0X.002) PC...
DVD RW drive is empty and do not open.
The drive may be bad or jammed up. There is a small pin sized hole to help you manually eject the drawer. Try popping it open and see if you can get it to unjam. Use a straightened out paper clip to fit into the hole and push somewhat firmly. Hopefully this will unjam the drive. If you cannot hear it trying to do something when you hit eject, or if you do not ever see flashing lights, the drive is probably bad.
Jun 03, 2010 | Sony VAIO VGC-JS130J/B 20.1-Inch...
HP Pavillion - DVD & CD drive will not open!
More or less in the centre of the draw front of both drives you should see a small hole.
Get hold of a paper clip and straighten it out, or use something similar, and press it into said hole. It should release the drive draw.
May 02, 2010 | Computers & Internet
When i press the button it does not open and does a strange noise
It is either stuck or jammed but try to use a paper clip in the emergency open hole. If your drive doesn't have a small emergency opening hole on the front of it, try to pull open the door, being careful not to break the plastic. The noise you hear is the gears for opening and closing the door.
Mar 16, 2010 | Dell Computers & Internet
Dvd drive is not working
Replace the DVD drive. They are inexpensive and it's not worth your time to try and fix this drive...
Feb 05, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Disc will not eject
There's probably only something jammed in the DVD drive... last one of these I fixed had a penny that my friend's daughter tried to stuff into the system. Once we opened up the Wii, the penny fell out and everything worked great. If there's nothing jammed in the drive, there may be gears or something in there broken. The following website has the full DVD drive... but I would try opening up the Wii first to see if something is jammed in there:
http://store.richspsxparts.com/wiiredvddr.html ~ Wii DVD Drive
http://store.richspsxparts.com/gbatrsc.html ~ Special "Nintendo" tri-wing screwdriver
Nov 17, 2009 | Nintendo Wii Console
Disk drive door stuck, won't close.
if your warranty is already voided then you could try openning up your xbox and then openning up your dvd drive and just see what its getting jammed up against
Jul 29, 2009 | Microsoft Xbox 360 Console
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Hp IQ780A has a2discs stuck in the dvd drive
Woah! You don't want to hear this but forcing a second disc into the drive has probably destroyed the drive read head. They are pretty tough and it might be able to survive but you will most certainly have to dismantle the drive to remove the DVD and not create any more damage. Kind of like scraping someone elses car in a parking lot. More damage is done when you try to back off of the other car than the initial hit. (not like that's ever happened to me :) )
Jan 08, 2009 | HP TouchSmart IQ770 PC Desktop
HP CD Drive Will Not Open
Take a pin/needle, and stick it in the small hole which should be somewhere on the front of the dvd rom. This should open the drive a bit, so that u can pull it out. then close it, and try if it opens then. If it doesnt, then you will have to grease the sides of the slide (from the bottom) a bit with vaseline. open and close it manualy a few times, and try then. If it still dont work then, then you may need to replace the little black bellt which it has just underneath the tray, towards the front of the drive.
Good luck
Dec 21, 2008 | HP Pavilion a810n (PP164AA) PC Desktop
Sony DRU-710A DVD±RW Dual Layer Burner Logo
227 people viewed this question
Top Sony Computers & Internet Experts
Computer Links
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
