Question about HP OfficeJet 7310 All-In-One InkJet Printer
When a page is printed a dialog box opens about the cartridges
When the print key is hit , a dialog box opens that says the correct black cartridge is installed then when you hit OK ,the box opens that says you have the correct color cartridge is installed. and then a box opens that says both cartridges are installed , How can this message be turned off?
  • cbuncle Dec 11, 2008
    I'll let you know when I get a chance to try it .Thanks
  • 169 Answers
If you perform the print head alignment procedure this will go away. You can do this using the HP utility program that installed with the print driver.
Carl
Posted on Dec 10, 2008
How do i do a print aligennment on a hp deskjet 6540
The printer automatically aligns the print cartridges after a new print cartridge is installed. You can also align the print cartridges at other times to ensure optimal print quality.
To align print cartridges:
1. Load letter-size or A4-size plain white paper in the In tray.
2. Open the printer Toolbox.
3. Click Align the Device.
4. Click Align , and then follow the onscreen instructions
Here are directions for how to open the printer Toolbox, in case you don't know:
The printer Toolbox contains a number of useful tools to enhance the printer performance.
Use the printer tools to perform the following tasks:
• Set the Auto-off function
• Clean the print cartridges
• Align the print cartridges
• Calibrate color
• Print a test page
• View estimated ink levels
To use the tools, open the Printer Properties dialog box, click the Services tab, and
then click the Service this device button.
AND, in case you don't know how to open the Printer Properties dialog box, here you go! :
The Printer Properties dialog box is also referred to as the Printer Preferences dialog box.
Opening the Printer Properties dialog box
Follow these steps to open the Printer Properties dialog box:
1. Open the file that you want to print.
2. Click File , click Print , and then click Properties or Preferences.
Good luck to you! I hope this helps.
Aug 07, 2014 | HP DeskJet 6540 InkJet Printer
How do I print ONLY in black and white? I can't seem to find the properties in the printer dialog box. Help! Thank you, Kim
You need to find the Color Options Features Tab; choose greyscale or Black Only.
Follow these steps to change the print settings for a single print job in Windows 7.
1.Open the document that you want to print. Click File , and then click Print . The Print window opens.
2.Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer setup , Printer , or Preferences .
3.In the Properties dialog box, select the print properties for the current print job, and then click OK .
Follow these steps to change the default print settings for all print jobs.
1.On the Windows taskbar, click the Windows icon, and then click Devices and printers .
2.Right-click the printer icon for your product, and then click Printing preferences .
3.Select your new default print settings, and then click OK .
Dec 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Oct 24, 2009 | HP DeskJet 845c Printer
I have installed a new black cartridge but print is not clear. i think i need to realign cartridges but dont know how. it is a lexmark x73. can you pls help
1 Select Print Control Program Cartridges Align Cartridges. For help, see page 8.
An alignment page prints and the Align Cartridges dialog box displays on the screen.
A number appears under each pattern. The test page that prints is similar to the one
shown.
2 For each alignment group on the test page, find the number that comes closest to
forming a straight line.
3 In the Align Cartridges dialog box, enter the numbers you selected on the test page.
4 After you have entered a number for all of the patterns, click OK.
http://www.lexmark.com/publications/pdfs/2007/x73/user_guide_en.pdf
Oct 23, 2009 | Lexmark X73 All-In-One InkJet Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    Pixma 4200 compatible ink cartridge problem help
    The ink detection is a critical function of the printer.
    Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
    I.E. It will seize eventually....
    Hopefully you didn't print much without the ink, and your heads are still in good shape...
    Here is a chip reset procedure....
    With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
    1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
    2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
    3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
    4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
    5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
    6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
    7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
    8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
    Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
    How to change cartridgeon HP desktop D4160
    from HP's web site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00641960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN Step one: Replace the old print cartridge
    1. Make sure the product is turned on.
    2. Open the print carriage access door.
    3. Wait until the print carriage moves to the right side of product and is idle and silent.
    4. Press down on the print cartridge to remove it from the slot, and then slide it out of the print carriage.
    5. Remove the new print cartridge from its packaging, and then carefully remove the plastic tape by using the pink pull tab. Figure 1: Remove the tape c00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
    6. Slide the print cartridge at a slight upward angle into the print carriage until it snaps into place. Figure 2: Inserting the print cartridge c00642241.gif
    7. Close the print carriage access door. WARNING: Keep both new and used print cartridges out of the reach of children.
    8. Wait until the print carriage moves to the right side of the product and is idle and silent.
    Step two: Align the new print cartridge
    1. Load Letter or A4 size, unused, plain, white paper in the input tray.
    2. Open the printer Toolbox . Follow these steps to open the printer Toolbox .
      1. From the File menu in the software program, click Print . The Print dialog box appears.
      2. Click the Properties button. The Print Properties dialog box appears.
      3. Click the Features tab.
      4. Click Printer services . The printer Toolbox appears.
    3. Click Align the Print Cartridges .
    4. Click Align , and then follow the on-screen instructions. The product prints a test page, aligns the print cartridges, and then calibrates the product. Recycle or discard the test page.
    Dec 23, 2007 | HP 83 3-ink Black UV Cartridge Multipack...
    Canon i455 not printing properly
    (i posted this for someone before)
    When you remove the black cartridge there will be electrical contacts inside the printer that lines up with some contacts on your cartridge, make sure these are clean
    Also, according to this printers manual, have you tried a printer head align?
    "(1) Open the Printer Properties dialog box. See Opening the Printer Properties dialog box directly from the Start menu
    (2) Click the Maintenance tab.
    (3) Click Print Head Alignment.
    Follow the instructions on the screen."
    Oct 31, 2007 | Canon i455 InkJet Photo Printer
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    42 people viewed this question
    Ben Johnson
