Question about HP Media Center m7260n (EG642AA) PC Desktop
HP power up issue
My hp was shut down inccorectly (someone pressed the power button) while another person was surfing the net. Now the pc won'w power up at all. The model is a hp Media Center PC m7664x. I've tried two different power cords and removing all the other perificals and no such luck. Not even a power light on the front. I do however get a light glowing green light on the back directly behind the power pack. Any thoughts?? All are welcome...
  • airrunhall Dec 11, 2008
    Thanks for Trying!
    I removed the power cable and held the power button for 7 sec w/o power cable and then tried to connect the power cable and turn on
    (Nothing happened)
    2) I reconnected power connector on the mother board and tred it
    (Nothing happened)
    3) I removed the memory and couldn't hear a beep beep! What does that mean?
    I didn't remove the PCI cards as you required only if I heard the beep on the memory.
    Any more ideas? Thanks!!
  • 61 Answers
Hi
you will have to remove the power cable and hold the power button for 7 sec w/o power cable and then try connection the power cable and turn on
2) reset the power connector on the mother board and try it
3) remove the memory and chk if you could listen to the beep if yes the mother board and power supply is fine so try removing the pci cards if any
Try those things
Regards
Samson Ved
Posted on Dec 10, 2008
Maintaining functioning of Hp f2105 monitor
I would suspect the monitors internal power supply has issues. If you are capable of soldering and know some electronics replacing bad capacitors is doable at home. Try joining badcaps.net and posting your monitor problems there as that is how I found the info I needed to repair my HP W2207 monitor.
Apr 21, 2013 | HP Pavilion Computers & Internet
HP DC7800 doesn't wake up (and power switch does nothing!)
Bad setting. If you press and hold the power button, the computer will shut off. That will keep you from having to unplug it.
Jan 28, 2013 | HP dc7800 Business Desktop Small Form...
Hp pavillion vista won't shut down
I think your at the point to do a Full System Recovery. Do you have a Factory Recovery Partition? You didn't supply the Model of HP or the OS you are using?
Jan 24, 2013 | Computers & Internet
My Hp Pavilion dv9831cl laptop quit working and won't power on, even with a full charge or plugged in. I press the start button, it lights for about a second then shuts off. Any suggestions? If I
Laptops use shared RAM, part of the main RAM is allocated as video RAM.
If the RAM is faulty then this could be the problem, get the RAM tested at your friendly computer repair shop.
Apr 06, 2012 | HP Pavilion dv9823cl Notebook
My HP Compaq nc8000 is stuck on
Try these things. Press and hold the power button until it shuts down. If that doesn't work, unplug it and leave it on until the battery dies, then find someone who can replace your power switch.
Mar 15, 2012 | HP Computers & Internet
I have a hp netbook laptop and it was working earlier but when I opened it it flashed my login screen and shut off and I can't get it back on and when I press the turn on button the charging button...
Remove the main battery and press power, sometimes this will solve the problem. If not, remove one stick of ram and power on, if not remove the second one and replace the first and try again. If no result it is probably a motherboard issue.
Mar 10, 2012 | HP Computers & Internet
When i press the power button on myn monitor i get a popup mon my screen "power button lockout" how do i solve this? i hve a window 7 hp computer. the power buton on the monitor was squeeze...
try..... it worked for me. Power Button Lockout is displayed.The monitor's Power Button Lockout function is enabled.
Press and hold the power button for 10 seconds to unlock
the power button function.
Thanks for using Fixya
Proton
Sep 11, 2010 | HP dx2300 Monitor Personal computer Intel...
My HP won't shut down. I hold the button to try a
Try this: Go to Control Panel-Display-Screen Saver-Power-Advanced tab and make sure that after the statement "When I press the power button on my computer" choose Shut down. Then turn off your pc with the power button (if it does not work unplug it, then try the button after Windows complete it's boot-up. Let me know how it went.
WBTech
Feb 01, 2010 | HP Computers & Internet
HP Pavilion dv6700 Entertainment wont boot
1. Power on (NO Disc.)
2. Press Pause
3. Enter 314159(with remote)
Display will show "FF"
4. Quickly press "0" (for all region)
5. Press pause
6. Power off and powere on after 20 secs.
Dec 09, 2009 | HP Pavilion DV6700T Notebook
My HP DV1000 keeps shutting down whenever I watch videos or do anything on my computer which is more than the basics of surfing the net. When it shuts down, the computer is hot so I attempted to remedy the...
hi this all hp is getting same problem
i have solve many, but u need to open up ur notebook and have to do all cleaning ,u can open ur notebok,
or else do onething, uses vaccum cleaning ,see behind ur laptop a fan site **** all dust through vaccum cleaner, it will clean and problen shouild be solve or else u have to open whole notebook
thanks a lot
Aug 16, 2009 | HP Pavilion dv1000 Notebook
HP Media Center m7260n (EG642AA) PC Desktop Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
